New member Username: KatiescodePost Number: 1 Registered: Mar-15 | Hi can anyone help me I am looking for a code for a radio in a Ford Focus 05 |
Silver Member Username: Decode_radioPost Number: 647 Registered: Jan-14 | serial numbers from radio please contakt me http://forum.kody-radio.pl |
New member Username: KatiescodePost Number: 2 Registered: Mar-15 | HI only info I can get on radio is it's a 6000cd not sure if that is any help. Thanks. |
Gold Member Username: DeksterPOLAND Post Number: 2109 Registered: Sep-12 | katiescode The radio SERIAL NUMBER is required for a code It usually begins with M or V followed by SIX digits ...such as M854331 or V555323 Sometimes pressing buttons 6 & 1 together or 6 & 2 will display this number Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing contact me: http://koddoradia.pl/ |
