New member Username: Kent_mPost Number: 3 Registered: Jan-15 | Light in radio and it says beep. Sometimes light in display and the letters spech for 1 sek |
New member Username: Jase1Post Number: 1 Registered: Jan-15 | Hi, I wonder if anyone can help? I replaced the battery in my wifes 2008 Renault Megane Scenic, but we don't have the code anywhere. Any ideas? ![]() |
Silver Member Username: IwosPost Number: 632 Registered: Jul-14 | Jase New member Username: Jase1 Hi, TRY CODE .. 7520 |
New member Username: Jase1Post Number: 2 Registered: Jan-15 | Excellent!!! Worked a treat. Thank you very much. J. |
Bronze Member Username: Danny147Post Number: 20 Registered: Dec-14 | kent you need to do this press 1 - 8 press 2 - 7 press 3 - 2 press 4 - 7 hold button 6 down until stereo beeps |
New member Username: JovanafpnPost Number: 1 Registered: Jan-15 | Please HELP Renault Scenic 2002. ![]() |
Silver Member Username: Titanum123Post Number: 907 Registered: Oct-13 | Jovana New member Username: Jovanafpn try code 6679 |
New member Username: DgleesonPost Number: 3 Registered: Jan-15 | Hi Guys I reported my radio dead some time back. So I couldn't enter the code. In case it helps anyone else, I just had to take radio out and plug it back in again. Some Odd fault with these radios. See http://www.boards.ie/vbulletin/showthread.php?p=83878310 Anyway all good now. And code worked. Thanks Denis |
New member Username: Sparkymarky1Airdrie, Lanarkshire Post Number: 2 Registered: Jan-15 | Hi need code for Renault scenic stereo any help would be much appreciated the number on stereo is 7700434424tj163 |
New member Username: Garage_kennethPost Number: 1 Registered: Jan-15 | Can anyone help me with a code for my Radio aswell? last 4 digits of serial number is L504 Best Regards Kenneth |
Silver Member Username: IwosPost Number: 638 Registered: Jul-14 | Kenneth New member Username: Garage_kenneth try code .. 2933 |
New member Username: Garage_kennethPost Number: 2 Registered: Jan-15 | ALMAIDA Thank you very much! |
New member Username: Chrisb555DurhamUk Post Number: 2 Registered: Jan-15 | Thanks ALMAIDA Code worked. |
New member Username: LindajaynePost Number: 1 Registered: Jan-15 | HI Could anyone help me out with a code for the wife's Clio 2 radio please? It would be much appreciated, Image is attached - I gather the bit required is L306? Thanks in advance Dave |
Silver Member Username: Decode_radioPost Number: 503 Registered: Jan-14 | Lin New member Username: Lindajayne CODE 3333 contakt me http://forum.kody-radio.pl |
New member Username: NasrPost Number: 2 Registered: Jan-15 | HI Could anyone help me out with a code for Clarion PU-2294A S/N : CL0401X0015029 THNX |
Gold Member Username: DeksterPOLAND Post Number: 2006 Registered: Sep-12 | nasr Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contact me: http://koddoradia.pl/ |
New member Username: LindajaynePost Number: 2 Registered: Jan-15 | Many thanks @ decode radio - thought I'd check this morning - answered in 1 minute! Works spot-on. Thanks again Dave |
New member Username: ThedanePost Number: 1 Registered: Jan-15 | Hey guys i have problem With mine aswell. just bought the car, but the radio code is messing bevandrede the provins owner changed the batterie... Renault 276 Radiostat 6010 [7700 433 074] Phillips 22dc461/62e 9022 214 61622 FD 11 99 27 2292484 Model no: 22DC461/62E Prod no: FD 1199272292484 Another label Says Code gravage 2292484 And third label Says 902221461622 22DC461/62E M/ch:292357 Thank you in advance guys, sorry if spelling mistakes. |
New member Username: NasrPost Number: 3 Registered: Jan-15 | Hi Dekster it s in Peugeot 306 car help me plz |
New member Username: ThedanePost Number: 2 Registered: Jan-15 | I looked abit closer at the labels and the Security code must be: T996 Its the last part of the number under the barcode Hope some1 Can help me out now? Thanks |
Silver Member Username: Titanum123Post Number: 909 Registered: Oct-13 | TheDane New member Username: Thedane try code 6056 |
New member Username: ThedanePost Number: 3 Registered: Jan-15 | Qwerty thank you a lot It Worked out perfectly |
New member Username: NasrPost Number: 4 Registered: Jan-15 | I really hope someone can help me |
New member Username: NasrPost Number: 5 Registered: Jan-15 | I really hope someone can help me car: peugeot 306 Model car-audio: PU-2294A S/N : CL0401X0015029 thnx |
Silver Member Username: IwosPost Number: 654 Registered: Jul-14 | nasr New member Username: Nasr Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. |
New member Username: TomysszPost Number: 1 Registered: Jan-15 | I really appreciate help if someone could find and say code for my radio which is blocked Here's the pic of information about radio http://i58.tinypic.com/2ebe920.jpg Thanks in advance |
Silver Member Username: Decode_radioPost Number: 510 Registered: Jan-14 | Thomas New member Username: Tomyssz CODE 5145 contakt me http://forum.kody-radio.pl |
New member Username: AustriainvestPost Number: 1 Registered: Jan-15 | Hello, i m from Austria , sorry for my bad english . Please help me to find my code from the radio in my Megane CC. I load my batterie and now i have to enter the code. The security code end numbers are Q048. Thanks a lot, Martin |
Silver Member Username: Titanum123Post Number: 922 Registered: Oct-13 | Martin Falkensteiner New member Username: Austriainvest try code 9965 |
New member Username: AustriainvestPost Number: 2 Registered: Jan-15 | It works ! Thanks a lot qwerty. Good Luck in your future , yours martin |
New member Username: ZukicodePost Number: 2 Registered: Jan-15 | please assist with the radio code security code ends with T884 |
Gold Member Username: DeksterPOLAND Post Number: 2018 Registered: Sep-12 | zuki CODE 6147 contact me: http://koddoradia.pl/ |
New member Username: Billmac1Post Number: 1 Registered: Jan-15 | Hi can someone help please, I put a new battery into my 2008 Grand scenic yesterday and cant find the radio code. Serial Number is 8200562686T D439 - SECURITY Many Thanks |
Silver Member Username: Titanum123Post Number: 927 Registered: Oct-13 | bill.mac1 New member Username: Billmac1 try code 2111 |
New member Username: Billmac1Post Number: 2 Registered: Jan-15 | Perfect thank you so much qwerty, really appreciate the help |
New member Username: JohnjopPost Number: 1 Registered: Jan-15 | Hi wonder if anyone can help me need a radio code for a renault megane 57plate Rnrdap70370925 Renrdw330-19 Bs030727925. K005 security |
Silver Member Username: IwosPost Number: 686 Registered: Jul-14 | Johnjop New member Username: Johnjop Hello, TRY CODE .. 5953 |
New member Username: JohnjopPost Number: 2 Registered: Jan-15 | Cheer for the quick reply and worked first time big help Thanks |
New member Username: ProkinPost Number: 1 Registered: Jan-15 | Make :RENAULT Model: :22DC259/62P TUNER LIST PROD NO: FD0400390166539 Part number/Model:7700 434 424 Manufacturer: :PHILIPS SECURITY NUMBERS: TOV 716 TOU392 RN259FY0166539 ![]() |
Silver Member Username: Decode_radioPost Number: 521 Registered: Jan-14 | Prokin New member Username: Prokin CODE 5656 or 4213 contakt me http://forum.kody-radio.pl |
Gold Member Username: DeksterPOLAND Post Number: 2025 Registered: Sep-12 | Prokin CODE 5656 contact me: http://koddoradia.pl/ |
New member Username: Vol209Post Number: 1 Registered: Jan-15 | Could you guys please help me out? Cant seem to get t the generator to work.. Code is I808 |
Silver Member Username: Decode_radioPost Number: 524 Registered: Jan-14 | Lex New member Username: Vol209 CODE 8327 or 2328 contakt me http://forum.kody-radio.pl |
New member Username: Vol209Post Number: 2 Registered: Jan-15 | Thanks alot dude! |
New member Username: Cmorris0Burton on trent, Staffordshire United Kingdom Post Number: 1 Registered: Jan-15 | hey anyone to help v461 8200607915t bs0508190968015 |
Silver Member Username: Titanum123Post Number: 943 Registered: Oct-13 | chris morris New member Username: Cmorris0 try code 4552 |
New member Username: Shelby_8510Post Number: 1 Registered: Jan-15 | Hi wonder if anyone can help me.I need a radio code for Becker Traffic Pro M/N: BE 4720 S/N: 15066263 Many Thanks! |
Silver Member Username: IwosPost Number: 703 Registered: Jul-14 | shelby_8510 New member Username: Shelby_8510 Hello, TRY CODE .. 55152 |
New member Username: Jono_wilkoPost Number: 1 Registered: Jan-15 | Hi people, any help for my radio please? Thanks in advance![]() |
New member Username: Rigz81Post Number: 1 Registered: Jan-15 | Can you help? Security code TOD 580 |
Silver Member Username: IwosPost Number: 706 Registered: Jul-14 | Jonathan Wilkinson New member Username: Jono_wilko Hello, TRY CODE .. 9758 |
Silver Member Username: IwosPost Number: 707 Registered: Jul-14 | Mike New member Username: Rigz81 try code .. 1450 |
New member Username: Jono_wilkoPost Number: 2 Registered: Jan-15 | Thank you so much ALMEIDA. really really thank you. |
New member Username: HarrisoncommercialSwadlincote, Derbyshire United Kingdom Post Number: 6 Registered: Jan-15 | Hi all i have a renault kangoo van and the radio requires a code... 281112231RT K870-Security Thanks in advance |
New member Username: Shelby_8510Post Number: 2 Registered: Jan-15 | Many thanks for the help ALMEIDA. radio is alive again. |
New member Username: Rigz81Post Number: 2 Registered: Jan-15 | Brilliant, thanks a lot. Your help is much appreciated. |
New member Username: Gdc88Post Number: 1 Registered: Jan-15 | Hi Newbie here, would anyone be able to generate a code for Mk2 Megane? Details are: R973 RN277F40460590 |
Silver Member Username: Titanum123Post Number: 948 Registered: Oct-13 | GC New member Username: Gdc88 try code 8046 |
New member Username: JslarsenPost Number: 1 Registered: Jan-15 | Hi, Changed my battery - need the radio code for my Renault Scenic: RNRDBEA0925462 RENRDW330-10 FD0910150925462 8200607918T Thanks in advance Schbeers |
Silver Member Username: IwosPost Number: 725 Registered: Jul-14 | Schbeers New member Username: Jslarsen Hello, Please, letters/numbers from the main bar code 8200xxxxtt123, 7200xxxxxtt123 or security code, as Q123 or T0U123 |
New member Username: SammbrownPost Number: 1 Registered: Jan-15 | Hiya. Could someone generate me a code for my renault Megane scenic please. Serial - 8200300859tn076 Model - renrdw13210 Please! Thank you |
Silver Member Username: IwosPost Number: 726 Registered: Jul-14 | Samm New member Username: Sammbrown Hiya, Try code .. 2924 |
New member Username: SammbrownPost Number: 2 Registered: Jan-15 | Thanks so much for the quick reply! Worked perfectly |
New member Username: JslarsenPost Number: 2 Registered: Jan-15 | Hi Almeida, 8200607918T H112(-SECUTITY) Sorry for not giving this info in the first post... Schbeers |
Silver Member Username: Titanum123Post Number: 952 Registered: Oct-13 | Schbeers New member Username: Jslarsen try code 4618 |
New member Username: NesoPost Number: 5 Registered: Jul-13 | hi I need code If you can help Code is for radio from Renault scenic 2001y. model no: 22DC279/62P prod no: FD0301130229108 TOT905 RN279F10229108 7700434425TT905 7700 434 425 |
Silver Member Username: IwosPost Number: 727 Registered: Jul-14 | neso New member Username: Neso Hello, TRY CODE .. 6082 |
New member Username: GusfrewPost Number: 1 Registered: Jan-15 | hi there any help appreciated. model . rnrd8460028047 product info . fd0206020028047 serial no . 8200550822t security . s179 |
New member Username: IgorppPost Number: 3 Registered: Oct-14 | hi can anyone help me for code i have pioneer DEH-2006RDSzrn XBEW8 7700845459 RN2006 T0145774 7700841008 QA51274 |
New member Username: GusfrewPost Number: 2 Registered: Jan-15 | not to worry got it ok. |
New member Username: Mrmac4Post Number: 1 Registered: Jan-15 | Can I please have the code for Q501. Thanks! |
Silver Member Username: Titanum123Post Number: 956 Registered: Oct-13 | J Mac New member Username: Mrmac4 try code 9426 |
New member Username: IgorppPost Number: 4 Registered: Oct-14 | hi can anyone help me for code i have pioneer DEH-2006RDSzrn XBEW8 7700845459 RN2006 T0145774 7700841008 QA51274 |
Silver Member Username: Titanum123Post Number: 958 Registered: Oct-13 | prilep New member Username: Igorpp sorry we can't help Main Dealer or a Decoding Service only for this code |
New member Username: IgorppPost Number: 5 Registered: Oct-14 | why you cant help me i need code for QA51274 |
New member Username: Mrmac4Post Number: 2 Registered: Jan-15 | Thanks for the reply qwerty, that worked a treat. Cheers! |
New member Username: Vicko75Post Number: 6 Registered: Nov-13 | Asked on here before for my code for grand scenic how do I find previous posts is it possible |
New member Username: Aimer_8Post Number: 2 Registered: Nov-14 | Please can you tell me the code for my Renault Megane Scenic. Battery went flat and no details from previous owner about what the code is! Thank. Model no: 22DC278/62R Prod no: FD0303270055547 |
Gold Member Username: DeksterPOLAND Post Number: 2034 Registered: Sep-12 | Aimer_8 post 14 or 15 digit number start on 7700 or 8200 contact me: http://koddoradia.pl/ |
New member Username: Aimer_8Post Number: 3 Registered: Nov-14 | Ok. Try: 8200150474TK937 Thanks. |
Silver Member Username: IwosPost Number: 755 Registered: Jul-14 | Aimer_8 New member Username: Aimer_8 TRY CODE .. 4122 |
New member Username: Aimer_8Post Number: 4 Registered: Nov-14 | Yay that worked. Thank you so much. If the battery goes again will it be the same code? |
New member Username: P3rygPost Number: 1 Registered: Feb-15 | Hi, could someone help with a code please, 8200562686T R319 Many thanks |
Silver Member Username: IwosPost Number: 757 Registered: Jul-14 | Perry New member Username: P3ryg Hello, TRY CODE .. 8644 |
New member Username: P3rygPost Number: 2 Registered: Feb-15 | Many thanks worked a treat. Does the change code if I disconnect the battery again or is it the same ? |
New member Username: RockabillygillyRotherham, Uk Uk Post Number: 1 Registered: Feb-15 | Can anyone help I've taken the battery off my 2002 scenic and now my radio won't work sec code Q021 Thanks |
Silver Member Username: Decode_radioPost Number: 527 Registered: Jan-14 | shane New member Username: Rockabillygilly CODE 9976 contakt me http://forum.kody-radio.pl |
New member Username: RockabillygillyRotherham, Uk Uk Post Number: 2 Registered: Feb-15 | Won't let me put any code in now ts just bleeping Any ideas |
Bronze Member Username: AymantnPost Number: 36 Registered: Dec-09 | Renault Radio Code | Do It Yourself | VIDEO TUTORIAL >>> https://www.ecoustics.com/electronics/forum/car-audio/723687.html |
New member Username: IgorppPost Number: 6 Registered: Oct-14 | can enyone help me where can i found serial or sec code on my PIONEER DEH-2006RDSzrn becayse i found just this RENAULT 7700 845 459 on radio box..iff anyone know some hotkeys for my radio to found serial or sec number pls tell me..thanks |
New member Username: NsarpeiPost Number: 1 Registered: Feb-15 | Can't get my radio code right. Can someone help? I dont know if these numbers on the car can help. Type: JMRG06, no:33851101, manufacturing oval plate:D701092, registration:8601341059 |
New member Username: Markus77Post Number: 1 Registered: Feb-15 | Hi Please can someone help me with the radio code of my mEgane scenic 2005 Model n renrdw131-10 Security x397 Product fd0805180302796 Thanks |
Silver Member Username: Titanum123Post Number: 967 Registered: Oct-13 | MArco New member Username: Markus77 try code 2601 |
New member Username: NsarpeiPost Number: 2 Registered: Feb-15 | I'm trying to locate the model and security number for my megane scenic 2005 model.Any helpto identify where I can locate this within the car? I need help to unlock the code for my radio and thought by entering the chassis number that would be enough information. Apparently, it seems that is not enough information hence the non reply to my query. The information i have from the person who sold the car to me are as follows. Car type: Renault Megane Scenic, year of manufacturer: 2005 (D.2) JMRG06, (E) VF1JMRG0633851101. If this information isn't helpful, then kindly show me where in the car i can locate the model, security and production numbers |
Bronze Member Username: Danny147Post Number: 22 Registered: Dec-14 | you need to remove the stereo and there is a sticker on it ,,, you might need to aquire some stereo pins to remove this |
New member Username: CharliecooperPost Number: 1 Registered: Feb-15 | Hello I've changed the battery on my daughters first car and now the radio asks for a code. Can you help us please? RNRDAN60072664 RENRDW330-09 BS0106300072664 8200607915T Q209-SECURITY |
Silver Member Username: IwosPost Number: 778 Registered: Jul-14 | CharlieCooper New member Username: Charliecooper Hello, TRY CODE .. 9779 |
New member Username: CharliecooperPost Number: 2 Registered: Feb-15 | Thank you ALMEIDA, that worked! |
Bronze Member Username: AymantnPost Number: 38 Registered: Dec-09 | Take a look at this video tutorial, very cool : |
