Help to find code for clarion
Username: Blackm
i Hope someone here can help to find the code for my autoradio clarion model: PN-2424M
and serial number: CL052950176973
Username: Decode_radio
Post Number: 501
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
contakt me http://forum.kody-radio.pl
