Renault kangoo radio code
Username: Dweller87
Serial is FD0506010034866 R332 security.
Any help would be greatly appreciated. Many thanks.
Username: Iwos
Post Number: 626
Antony
Username: Dweller87
TRY .. 8653
Username: Dweller87
Doesn't seem to work unfortunately
Username: Dweller87
This is the serial number:
8200354519T R338 SECURITY
Think I put the wrong part of the number in the original post. Sorry. I used a bar code scanner and it have me a different number so the serial on the radio by mistake.
Username: Iwos
Post Number: 627
Antony
TRY CODE .. 8677
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press and hold preset " 6 " To Enter
