Gold Member Username: Tremor1127Fi Post Number: 2733 Registered: Aug-06 | I need a transmission line enclosure designed. |
Gold Member Username: Joe1234Post Number: 2006 Registered: May-09 | Not worth it in a car as size can be about 3X a ported box, 6.5" to 10" subs with qts < 0.4 and qms < 7 are candidates, if you insist on doing it you can do it yourself with this: http://dbdynamixaudio.com/dual-fold-on-axis-transmission-line-enclosure-calculat or/ Ram designs can take the time to do the cute labyrinth for a fee. By the time you are done you will find that the results were not worth the box size and the effort to build, at least most people feel that way in the end.. best of luck. |
