Code radio please
Username: Maximehabert1
radio becker solitude rds
serial : BE239V5001122
type : solitude
Username: Regrooster
Post Number: 11769
#Maxime Habert
BE239V5001122
Please check Serial Number again
try with serial no : V5001122
Username: Dekster
POLAND
Post Number: 1992
Maxime Habert
Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
Otherwise try your Ford Dealer or a Radio Decoding Service
contact me: http://koddoradia.pl/
