Lost radio code
Username: Tol8
Hi,
I lost the security code for my Clarion car radio/cd player.
serial: CL052920058546
part nº: PN2424M
Can anyone help me pls? Thanks!
Username: Decode_radio
Post Number: 445
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
contakt me http://forum.kody-radio.pl
Username: Tol8
Ok, thank u...
the only label on my radio is this one:
there's no other label sticked on.
Username: Iwos
Post Number: 565
tol8
Username: Tol8
Hi,
Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service
It is unlikely to be available for free or cheap from anywhere on the Internet.
Username: Tol8
I see...
ok, thanks for the answers.
