New member Username: Tol8Post Number: 1 Registered: Dec-14 | Hi, I lost the security code for my Clarion car radio/cd player. serial: CL052920058546 part nº: PN2424M Can anyone help me pls? Thanks! |
Silver Member Username: Decode_radioPost Number: 445 Registered: Jan-14 | Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
New member Username: Tol8Post Number: 2 Registered: Dec-14 | Ok, thank u... the only label on my radio is this one: there's no other label sticked on. |
Silver Member Username: IwosPost Number: 565 Registered: Jul-14 | tol8 New member Username: Tol8 Hi, Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet. |
New member Username: Tol8Post Number: 3 Registered: Dec-14 | I see... ok, thanks for the answers. |
