Bauplunkt car radio code please
Username: Ourkarma
Fernvale, Qld Australia
have purchased a bauplankt head unit from car wreckers with no codes. If you can provide codes i would appreciate it. Serial no is
BP 2252 3160 7641
there is also only 1 label, with the following;
NO.: 92 096 466
Type: SYS 3A
Vin for the wrecked car it came out of if required if required, but didnt see anyone posting it
any help im grateful, regards Dan
Username: Dekster
POLAND
Post Number: 1949
Danny Adams
CODE 5141 or 1141
contact me: http://koddoradia.pl/
Username: Decode_radio
Post Number: 385
Danny Adams
Username: Ourkarma
CODE 1141
contakt me http://forum.kody-radio.pl
Username: Ourkarma
thanks heaps regards Dan
Username: Domenik
salve ragazzi mi potreste aiutare per favore ho acquistato un furgone con un autoradio fiat blaupunkt bp439240690859 bp7644392316 prod.fiat nr.156046410 ma non mi anno fornito del codice autoradio vi sarei molto grato se me lo potreste fornire grazie.
Username: Iwos
Post Number: 345
domenik
Username: Domenik
try code .. 4616
Username: Domenik
per ora ringrazio tanto ALMAIDA per il piacere che mi ha fatto domani provo ad inserirlo e vi faccio sapere buon proseguimento nel forum a presto ragazzi grazie ancora ad AL.
Username: Ourkarma
thank you very much 51 worked!!
Username: Myles_44
Hi could I get a radio code for Alfa 147 no. Bp330147056338 and 7643301316
Thanks in advance
Username: Myles_44
Thanks in advance
Username: Iwos
Post Number: 534
James d
Hi,
TRY CODE .. 4454
