New member Username: Lilslugger01Post Number: 1 Registered: Oct-14 | Hi new user Fiat punto Serial number : BP937213840680 Part number/model 7649372316/7352725690 Thank you |
Silver Member Username: Titanum123Post Number: 779 Registered: Oct-13 | andrew New member Username: Lilslugger01 try code 3535 |
New member Username: Lilslugger01Post Number: 2 Registered: Oct-14 | Will try it thank you so much. |
New member Username: SpirostaPost Number: 1 Registered: Oct-14 | Hello there need help about code on a nissan micra. Serial N. is BP234632519632 part N 7642346318. Thank you. |
Silver Member Username: Decode_radioPost Number: 388 Registered: Jan-14 | spirosta New member Username: Spirosta CODE 3216 contakt me http://forum.kody-radio.pl |
New member Username: RenelimarjRIO DE JANEIRO - Brasil, RJ Post Number: 1 Registered: Oct-14 | Preciso do code. Ap�s um acidente o radio ficou pedindo o code. Algu�m pode me ajudar? FIAT BLAUPUNKT PUNTO / FIAT 310 MP3 BSA MEDIUM 7647 392 316 / 1001754850 BP739280343493 |
Gold Member Username: DeksterPOLAND Post Number: 1950 Registered: Sep-12 | Rene Lima Post the 14 character Serial Number beginning BPxxxxxx found stamped in the metal casing contact me: http://koddoradia.pl/ |
Silver Member Username: Decode_radioPost Number: 395 Registered: Jan-14 | Rene Lima New member Username: Renelimarj CODE 5224 contakt me http://forum.kody-radio.pl |
New member Username: RenelimarjRIO DE JANEIRO - Brasil, RJ Post Number: 2 Registered: Oct-14 | Grato meu amigo! Muito obrigado! |
New member Username: MangoaPost Number: 1 Registered: Oct-14 | Hi, I need a radio code for this: serial no BP854382477753 part no 7648543316 |
Silver Member Username: IwosPost Number: 369 Registered: Jul-14 | Stefan New member Username: Mangoa Hi, Try code .. 6464 |
New member Username: MangoaPost Number: 2 Registered: Oct-14 | Thank you so much Almaida, it worked well. |
New member Username: ArdveenPost Number: 1 Registered: Oct-14 | Hi, just wondering if it was possible to get a code for my fiat punto radio? Serial no. BP632767500203 Thanks very much in advance |
Silver Member Username: IwosPost Number: 376 Registered: Jul-14 | Frank O'Donnell New member Username: Ardveen Hi, Try code .. 6226 |
Silver Member Username: Titanum123Post Number: 792 Registered: Oct-13 | Frank O'Donnell New member Username: Ardveen try code 6226 |
New member Username: Tania68Post Number: 1 Registered: Oct-14 | Hi there, can anyone help me, need a radio code for my fiat punto, blaupunkt bp937227223277 many thanks in advance |
Silver Member Username: IwosPost Number: 378 Registered: Jul-14 | tania68 New member Username: Tania68 Hi, try code .. 3662 |
New member Username: Monki_17Post Number: 1 Registered: Oct-14 | Hola buenos dias, quisiera saber si me podrian decir el codigo para desbloquear la radio de mi fiat punto. El numero de serie es: -BP632967473410 Gracias de antemano un saludo. |
Silver Member Username: IwosPost Number: 379 Registered: Jul-14 | Pinerd New member Username: Monki_17 Hola Teu codigo ..4665 |
New member Username: Monki_17Post Number: 2 Registered: Oct-14 | Hola perdon porpreguntar tanto. antes he puesto mal li numero de serie El corecto es: --BP632967473420 Un SAludo Muchisimas GRacias! |
Silver Member Username: Titanum123Post Number: 793 Registered: Oct-13 | Pinerd New member Username: Monki_17 try code 5134 |
New member Username: JromaoPost Number: 1 Registered: Oct-14 | Hi, new member!! I need code for the radio with the following details: FIAT 310 MP3BSA MEDIUM 7 647 392 316 PORTUGAL 815BP739276457623 tHANKSSS |
Silver Member Username: IwosPost Number: 383 Registered: Jul-14 | jromao New member Username: Jromao Hi, TRY CODE .. 4224 |
New member Username: JromaoPost Number: 2 Registered: Oct-14 | Hi, new member!! I need code for the radio with the following details: FIAT 310 MP3BSA MEDIUM 7 647 392 316 PORTUGAL 815BP739276457623 tHANKSSS |
Silver Member Username: IwosPost Number: 388 Registered: Jul-14 | jromao New member Username: Jromao Duplicate post, already answered |
New member Username: Cv_veenuPost Number: 1 Registered: Oct-14 | sir i am new member, username: cv _veenu my lost my code for my fiat linea blaupunkt audio, its number is BP635499689560 |
Silver Member Username: IwosPost Number: 399 Registered: Jul-14 | pkreddy New member Username: Cv_veenu Hi, TRY CODE .. 2151 |
New member Username: Cv_veenuPost Number: 2 Registered: Oct-14 | thank you very much, for quick response... |
New member Username: Bigian1972Post Number: 3 Registered: Oct-14 | Hi I need a code for a 2000 model punto radio cassette pls |
New member Username: NunoluisPost Number: 1 Registered: Oct-14 | Hi, i am new member!! my car run out of battery and now i need the code to use the radio. the radio has the following details: BP - Nr. 7646383316 Prod. Nr Fiat 7354524840 Thank you in advance, nuno |
Silver Member Username: IwosPost Number: 404 Registered: Jul-14 | nuno New member Username: Nunoluis Hi, Post the 14 character Serial Number beginning BPxxxxxx found stamped in the metal casing |
New member Username: NunoluisPost Number: 2 Registered: Oct-14 | Hi Almaida Thank you for the fast answer The code is BP638389538199 Best regards Nuno |
Silver Member Username: IwosPost Number: 405 Registered: Jul-14 | nuno New member Username: Nunoluis Hi Nuno, TRY CODE .. 6456 |
New member Username: NunoluisPost Number: 3 Registered: Oct-14 | Thank you Almaida! |
New member Username: Gt1987Post Number: 1 Registered: Oct-14 | Help please. Looking for a code for my fiat punto blaupunkt radio with the following details: Manufacturer: Blaupunkt Radio Code Serial Number: BP237634045266 Part Number: 7642376316 Thank you in advance!! |
Silver Member Username: IwosPost Number: 409 Registered: Jul-14 | GT1987 New member Username: Gt1987 TRY CODE .. 1545 |
New member Username: Gt1987Post Number: 2 Registered: Oct-14 | Many Thanks Almaida! |
New member Username: Madlock221111Post Number: 1 Registered: Nov-14 | Hi i need code for my radio in punto bp937215301495 Thanks |
Gold Member Username: DeksterPOLAND Post Number: 1961 Registered: Sep-12 | Maddie CODE 6551 contact me: http://koddoradia.pl/ |
Silver Member Username: Decode_radioPost Number: 407 Registered: Jan-14 | Maddie New member Username: Madlock221111 CODE 6551 contakt me http://forum.kody-radio.pl |
New member Username: LindhardtPost Number: 1 Registered: Nov-14 | Hi, I need code for Blaupunkt radio BP237534065618 7 642 375 316 Thank you very much |
Silver Member Username: IwosPost Number: 421 Registered: Jul-14 | Lasse Lindhardt New member Username: Lindhardt Hi, TRY CODE .. 5336 |
New member Username: LindhardtPost Number: 2 Registered: Nov-14 | It works... thanks |
New member Username: Insane990Split, Type a choic... Croatia Post Number: 1 Registered: Nov-14 | Hi, Can You please help. Need the code for my Blaupunkt radio; 815 BP738971996506 7647389316 |
Silver Member Username: IwosPost Number: 423 Registered: Jul-14 | Insane990 New member Username: Insane990 Hi, TRY CODE .. 4254 |
New member Username: Insane990Split, Type a choic... Croatia Post Number: 2 Registered: Nov-14 | Thank You ALMAIDA!! There are few good people left as yourself... |
New member Username: Bad127Post Number: 1 Registered: Nov-14 | Hi! I canÂ't calculate the right code myself, any help? Fiat Punto 2001 BP9372Y366045 BP-NR 7649372316 prod nr 735272569 |
New member Username: Bad127Post Number: 2 Registered: Nov-14 | Sorry right bp is: BP9372Y3660453 |
Silver Member Username: Titanum123Post Number: 800 Registered: Oct-13 | Jake New member Username: Bad127 try code 3533 |
Silver Member Username: IwosPost Number: 433 Registered: Jul-14 | Jake New member Username: Bad127 Hi, TRY CODE .. 5166 |
Silver Member Username: IwosPost Number: 434 Registered: Jul-14 | Jake New member Username: Bad127 SORRY? CODE .. 3533 |
New member Username: H13Post Number: 1 Registered: Nov-14 | I can you calculate a code for Fiat Punto Mp3? BP237634039531 7 642 376 316 |
Silver Member Username: IwosPost Number: 439 Registered: Jul-14 | h13 New member Username: H13 hi, try code .. 1463 |
New member Username: GeordierejectPost Number: 1 Registered: Nov-14 | I would very much appreciate it if you could find a code for the following Blaupunkt cd player BP137623283327 No. 7641376316 |
Silver Member Username: IwosPost Number: 440 Registered: Jul-14 | Stuart New member Username: Geordiereject HI, try code .. 2133 |
New member Username: Bad127Post Number: 3 Registered: Nov-14 | qwerty & ALMAIDA 3533 correct. Thank you very much!!! |
New member Username: HeadshotosPost Number: 1 Registered: Nov-14 | I'd be grateful if you could help me with my code.. i can't find any code card.. the model should be fiat punto 2004 if it helps, blaunpunkt cd188 i think.. BPN 7642375316 ProdN 735337934 SN BP237547040905 |
New member Username: Realwan44Post Number: 6 Registered: Jul-13 | please I need radio code for Peugeot 206 blaupunkt niv2 s/no;BP814618706706 part 7648146392 many thanks. |
New member Username: SicurezzaPost Number: 1 Registered: Nov-14 | Hi I have a fiat punto. my code is BP143026022934 7 612 001 433 thanks |
Silver Member Username: Decode_radioPost Number: 414 Registered: Jan-14 | headshotos New member Username: Headshotos CODE 5566 contakt me http://forum.kody-radio.pl |
New member Username: PrconeWormerveer, NoordHolland Netherlands Post Number: 1 Registered: Nov-14 | Hi, I need one for my panda. Model: Fiat 169 CD Part Number: 7 643 385 316 Serial Number: 815BP338548895606 I hope you can help me. |
Silver Member Username: IwosPost Number: 450 Registered: Jul-14 | Max Hi, TRY CODE .. 1563 |
New member Username: SicurezzaPost Number: 2 Registered: Nov-14 | Hi, do you need more info for my radio? BP143026022934 7 612 001 433 |
Silver Member Username: IwosPost Number: 451 Registered: Jul-14 | sicurezza Hi, TRY CODE .. 2414 or 2614 |
Silver Member Username: IwosPost Number: 452 Registered: Jul-14 | realwan code .. 5165 |
New member Username: HeadshotosPost Number: 2 Registered: Nov-14 | "Decode_radio" you're the man my friend!! i really can't express how thankfull i am to you! keep going guys! |
New member Username: SicurezzaPost Number: 3 Registered: Nov-14 | thank you almaida, 2614 worked! |
New member Username: CoccobelloPost Number: 1 Registered: Nov-14 | Hello Can someone help me please? I have lost my code from my Radio :-( 815BP854586291686 Thank you very much! |
Silver Member Username: IwosPost Number: 453 Registered: Jul-14 | coccobello Hello, TRY CODE .. 2431 |
New member Username: Dennie_van_eschPost Number: 1 Registered: Nov-14 | hello ALMAIDA can you plz give me the radio code of fiat punto LOW radio BP937227238531 THANK YOU VERY MUCH |
Silver Member Username: IwosPost Number: 464 Registered: Jul-14 | dennievanesch Hello, TRY CODE .. 6136 |
New member Username: TazilloPost Number: 1 Registered: Nov-14 | Hello Can someone help me please? I have lost my code from my Radio :-( FA646170116811 Thank you! |
Silver Member Username: Titanum123Post Number: 809 Registered: Oct-13 | david acacio exposito New member Username: Tazillo Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet |
New member Username: TazilloPost Number: 2 Registered: Nov-14 | Thanks for responding so quickly. Ire at Fiat and have charged me. a greeting |
New member Username: CoccobelloPost Number: 2 Registered: Nov-14 | Hello Almaida Thank you very much. But Radio is blocked since yesterday and it comes the notice "WAIT". What can I do now? Thanks a lot |
Silver Member Username: IwosPost Number: 471 Registered: Jul-14 | coccobello New member Username: Coccobello Hi, Write all the letters and numbers on the labels and engraved on the metal casing of the radio. |
New member Username: MmhamoudaPost Number: 1 Registered: Nov-14 | Please Help me, please this is very IMPORTANT I forgot my car radio code It's a blaupunkt PALIO / FIAT CC serial number: 815 BP137123149938 part number: 7 641 371 316 please reply ASAP you will make me a big favor thanks in advance |
Silver Member Username: IwosPost Number: 474 Registered: Jul-14 | MMHamouda try code .. 4342 |
New member Username: PvisPost Number: 2 Registered: Nov-14 | Can i have the code for 7649372316 BP9372X0834775 please? |
Silver Member Username: Decode_radioPost Number: 425 Registered: Jan-14 | petri New member Username: Pvis CODE 1122 contakt me http://forum.kody-radio.pl |
New member Username: PvisPost Number: 3 Registered: Nov-14 | Thanks! unfortunatly code didn't work |
New member Username: GjoniPost Number: 1 Registered: Nov-14 | bp237546897540 |
Silver Member Username: IwosPost Number: 478 Registered: Jul-14 | gjoni troksi code .. 3636 |
New member Username: AvioPost Number: 1 Registered: Nov-14 | Can i have the code for BP9372Y1120156 7649372316 BP-NR.7649372316 ProdNrFiat 735272569 thanks in advance . |
Silver Member Username: IwosPost Number: 491 Registered: Jul-14 | avio New member Username: Avio TRY CODE .. 5125 |
New member Username: LudwigshafenPost Number: 1 Registered: Nov-14 | Please help me, i Need a code for: BP237547040189 BP-NR.7642375316 Prod Nr. Fiat 735337934 Thank you |
Gold Member Username: DeksterPOLAND Post Number: 1974 Registered: Sep-12 | Lou CODE 3331 contact me: http://koddoradia.pl/ |
New member Username: CoccobelloPost Number: 3 Registered: Nov-14 | New member Username: Coccobello Hi, Write all the letters and numbers on the labels and engraved on the metal casing of the radio @almaida: 815BP854586291686 Fiat 199 MP3 SB05 Small 2 Abarth 7 648 545 316 e1 034502 But Radio is still blocked. :-( I can't insert new codes :-( |
Silver Member Username: IwosPost Number: 494 Registered: Jul-14 | coccobello code .. 2431 If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible. Code Entry as Follows: Switch Radio On - Display Shows " CODE - - - - " Enter CODE in the order it is read: For Example, To Enter Code 1234 Press Preset 1 then 2 then 3 then 4 The Code will Enter Itself Automatically |
New member Username: VikenbakPost Number: 1 Registered: Nov-14 | Hello, I have bought a new post but i dont have the code.. I search on the net how to know it and i've found this site! Its a BLAUPUNKT I read on the post these informations serial part (i think) : 815BP533266752907 part number : 7 645 332 316 Can you give me the code with these informations ? Thanks in advance and sorry for my English (i'm french..). Viken |
Silver Member Username: Decode_radioPost Number: 427 Registered: Jan-14 | viken New member Username: Vikenbak CODE 2453 contakt me http://forum.kody-radio.pl |
New member Username: VikenbakPost Number: 2 Registered: Nov-14 | Thank you very much !! it's good now! Viken |
New member Username: Dtc67Post Number: 1 Registered: Nov-14 | Hello! Just got a Punto with radio asking for code.. It's Blaupunkt unit. BP-nr. 7 649 372 316 Prod. Nr. Fiat 735 272 569 Serial BP9372Y3574566 Any help? Thanks in advance! |
Silver Member Username: IwosPost Number: 499 Registered: Jul-14 | KL Hello, TRY CODE .. 6511 |
New member Username: Dtc67Post Number: 2 Registered: Nov-14 | It worked, thank you for your super fast help! Cheers, KL |
New member Username: Punto10Post Number: 1 Registered: Nov-14 | Hi im after a code for a fiat punto mk2 BLAUPUNKT radio Thankyou bp number-937213833211 |
Silver Member Username: IwosPost Number: 502 Registered: Jul-14 | punto hi, try code .. 6652 |
New member Username: Punto10Post Number: 2 Registered: Nov-14 | outstanding service, Thankyou very much |
New member Username: AthamasPost Number: 1 Registered: Nov-14 | Hi there, can anyone, please please, help with getting Blaupnkt radio code for Fiat Punto CD? (2003) BP237534088125 BP-Nr. 7642375316 Prod. Nr. Fiat 735337934 Any help on that would be more than highly appreciated. Thanks a lot in advance. |
New member Username: Fer01Post Number: 1 Registered: Nov-14 | Hello, Garage reset my radio and I don't know the code. Fiat punto 2001 blaupunkt radio LOW BP-nr. 7 649 372 316 Prod. Nr. Fiat 735 272 569 Serial BP9372Y3657233 Can you help me with the code? Thanks very much |
