Need a radio code from my Renault Grand Scenic 04 plate
Username: Steffieg19
Can anyone help with a radio code? Battery was disconnected. Upload
Username: Dekster
POLAND
Post Number: 1971
Steffieg19
CODE 6977
contact me: http://koddoradia.pl/
Hasn't worked. Can't enter code, it's still flashing
Username: Dekster
POLAND
Post Number: 1972
Steffieg19
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Then " 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " ¬ " Until A Beep Is Heard
Sorry it did work, (after pressing & holding 6, thanks again google) thanks very much! :D
