Blaupunkt CAR 300 F (opel zafira code)
Username: Rubanu
Hi,
I need a code for my opel zafira, which has a CAR 300 F Blaupunkt audio player in it
The serial number is GM030M23018812
The battery went flat and the player is asking for code.
Thank you in advance.
Regards Robert
Username: Iwos
Post Number: 468
RBN
Hi,
TRY CODE .. 7424
Username: Rubanu
tryed this one how do I press number seven?, I have till 6 the numbers on deck, have no display, can't see what numbers I'm pressing
Username: Rubanu
got it how the number entering works, still not working I'm doing the next things:
contact on
switch off radio
pressing AS -radio on -
entering code
Do not know how to memorize I'm pressing AS and nothing is happening
Username: Rubanu
Thank you very much Almaida for the code , unfortunately it doesn't work
Username: Iwos
Post Number: 470
RBN
Username: Rubanu
Hi,
The code is good for the serial number cited.
Please note that code entry is only possible with the ignition switched on, and in the order shown below. If the display shows a number less than 10, and the word SAFE, then the unit may be codelocked. If this is the case, leave it switched on for up to two hours and a further attempt at code entry should be possible.
Code Entry as Follows:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
