Clarion Radio code please
Username: Captain1
Oxford, Oxfordshire United Kingdom
Please can someone get me a radio code for a clarion PU-2294B(D) Serial CL040220734349
Many Thanks
Username: Titanum123
Post Number: 808
Chris Benton
Username: Captain1
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
