Ayuda código 22RC200/65S
Username: Rada_antoniohotmailcom
Hola:
Necesito codigo por desconecsion
96 346 767 80
HLZ14
Modelo 22RC200/65S
Serie: CL0402X0089582
Muchas Gracias
Username: Decode_radio
Post Number: 405
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
contakt me http://forum.kody-radio.pl
