Amp won't turn on
Username: Omgitzmory
So I hooked up my amp and sub yesterday and it as working perfectly fine. But this morning I turn on my car and realize there's no bass. So I pop my trunk and realize my amp isnt on. The project light is on but the power light isn't. I check my remote wire and it's still in tact. I looked at all the wires hooked up to the amp and it looks like it's all still connected. Can somebody tell me what the problem is please. Thank you. Might I also add that my car wouldn't start so I pop my hood and my negative was loose so I hooked it back on. Just wondering if this is a possibility of a blown fuse.
Username: Joe1234
Post Number: 1966
If your amp has external fuses on it you can check them out.
Username: Rickywilliams
They took the fuse off circuit board
