Silver Member Username: IwosPost Number: 173 Registered: Jul-14 | Srecko New member Username: Cesarec hi, try code .. 1265 |
New member Username: Rachaelross30Post Number: 1 Registered: Sep-14 | Hi, new member!! I need code for the radio with the following details: BP - Nr. 7649374316 Prod. Nr Fiat 735272570 also how do i input the code? as all that shows up on the radio right now is "check" Thank you in advance, Rach |
Silver Member Username: IwosPost Number: 184 Registered: Jul-14 | Rachael Ross New member Username: Rachaelross30 you must give me the reference BP9374xxxxxxxx so I can give you the code. |
New member Username: Rachaelross30Post Number: 2 Registered: Sep-14 | Hi, where would i find the code? those two were the only ones i could see on the bottom of the stereo. is it BP7649374316? |
Gold Member Username: DeksterPOLAND Post Number: 1897 Registered: Sep-12 | Rachael Ross Post the 14 character Serial Number beginning BP9374X1234567 found stamped in the metal casing contact me: http://koddoradia.pl/ |
New member Username: Rachaelross30Post Number: 3 Registered: Sep-14 | Hi, Thanks! I have found it. the number is: BP9374Y0969503 Thanks again! |
Silver Member Username: Decode_radioPost Number: 316 Registered: Jan-14 | Rachael Ross New member Username: Rachaelross30 CODE 4422 contakt me http://forum.kody-radio.pl |
New member Username: ToñoestradaPost Number: 1 Registered: Sep-14 | hola tengo un fiat punto con radio blaupunkt y necesito el codigo. bp 237433988471 7 642374316 gracias de antemano |
Silver Member Username: IwosPost Number: 195 Registered: Jul-14 | toñoestrada New member Username: Toñoestrada Hola, Teu Codigo .. 5236 |
New member Username: ToñoestradaPost Number: 2 Registered: Sep-14 | hola me gustaria saber como puedo quitar el "wait" del blaupunkt del fiat punto para introducir el code muchisimas gracias |
Silver Member Username: IwosPost Number: 203 Registered: Jul-14 | toñoestrada New member Username: Toñoestrada Let it turn about 2 hours or more until it asks the code. |
New member Username: MiglionicoPost Number: 1 Registered: Sep-14 | hi have a blaupunkt radio fiat punto 199 the bp 7646329316 fiat nr 7354295800 can not find the code unfortunately. could someone help me? my emsil is lm11.02@web.de |
Silver Member Username: IwosPost Number: 204 Registered: Jul-14 | Rocco New member Username: Miglionico hi, Please reference BP6329x1234567 |
New member Username: OaktreePost Number: 1 Registered: Sep-14 | Hi lovely helpful people i need a code for a blaupunkt cassette player from a fiat punto mk2b. The BP number is - 237459497306 Many thanks. |
Silver Member Username: IwosPost Number: 217 Registered: Jul-14 | oaktree New member Username: Oaktree Hi, Try Code .. 6424 |
New member Username: OaktreePost Number: 2 Registered: Sep-14 | Thanks a lot ALMAIDA my friend, that works. |
New member Username: AlpamisPost Number: 1 Registered: Sep-14 | Hi, I take a photo my tape help please Photo link : http://imgur.com/xqhSpjt |
Silver Member Username: Decode_radioPost Number: 326 Registered: Jan-14 | alpamis New member Username: Alpamis sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: AlpamisPost Number: 2 Registered: Sep-14 | Upss thank you |
New member Username: Nico019Post Number: 1 Registered: Sep-14 | Hi, I need code for Blaupunkt radio ( fiat punto mk2 / 2001. ) BP 9372Y3609724 BP-Nr. 7 649 372 316 Prod. Nr. 735 272 569 Thank you very much |
Silver Member Username: IwosPost Number: 223 Registered: Jul-14 | nico019 New member Username: Nico019 Hi, Try Code .. 1156 |
New member Username: Nico019Post Number: 2 Registered: Sep-14 | It works, thank you very much Almaida ;) |
New member Username: MitchellvdkPost Number: 1 Registered: Sep-14 | Hi, I need a code for my Blaupunkt radio (fiat punto 1.2 / 2000). I can only enter numbers from 1 to 6. BP 9372Y3598354 BP-Nr. 7 649 372 316 Prod. Nr. 735 272 569 Thanks in advance! |
Silver Member Username: Titanum123Post Number: 700 Registered: Oct-13 | mitchellvdk New member Username: Mitchellvdk try kode 6654 |
New member Username: MitchellvdkPost Number: 2 Registered: Sep-14 | Qwerty thanks a lot, it worked! |
New member Username: NelsinjrPost Number: 1 Registered: Sep-14 | sERIAL BP449582731535 Part number 7644495091 |
Platinum Member Username: RegroosterPost Number: 11748 Registered: Aug-08 | #New member Username: Nelsinjr Try code 1151 |
New member Username: Duncan80Post Number: 1 Registered: Sep-14 | BP nummer: 7647386316 S/N: 815BP738672264208 Fiat nummer: 7354469710 |
Silver Member Username: IwosPost Number: 272 Registered: Jul-14 | Duncan New member Username: Duncan80 try .. 3313 |
New member Username: Duncan80Post Number: 2 Registered: Sep-14 | Tnx |
New member Username: Tx1Post Number: 1 Registered: Sep-14 | Please; I need a code for my Blaupunkt Navi-radio: 881BP239555441876 7612002395 Thanks |
New member Username: DakizaPost Number: 1 Registered: Sep-14 | Hello i need a code for my blaupunkt radio for Fiat Grande punto 2006 BP.NR:7 645 353 316 FIAT.NR:735 416 230.0 S/N:BP535357293306 Thanks ! |
Silver Member Username: Titanum123Post Number: 724 Registered: Oct-13 | Davor New member Username: Dakiza try code 2223 |
New member Username: SofijasPost Number: 1 Registered: Sep-14 | please help for radio code for fiat punto low 2000 blaupunkt - portugal bp937215285208 7649372316 Thx in advance. |
Silver Member Username: Titanum123Post Number: 725 Registered: Oct-13 | sofijas New member Username: Sofijas try code 5424 |
New member Username: Tx1Post Number: 2 Registered: Sep-14 | Can nobody help me with my code? 881BP239555441876 7612002395 |
Gold Member Username: DeksterPOLAND Post Number: 1934 Registered: Sep-12 | felix Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet contact me: http://koddoradia.pl/ |
New member Username: TyrantPost Number: 1 Registered: Oct-14 | I lost my radio code BMW reverse, pls help me. BP3835R8507688 7643835340 Thx |
Silver Member Username: Titanum123Post Number: 728 Registered: Oct-13 | Georgi New member Username: Tyrant try code 3732 |
New member Username: TyrantPost Number: 2 Registered: Oct-14 | It works. Many thanks "qwerty". |
New member Username: Huron12Post Number: 1 Registered: Oct-14 | Can nobody help me with my code OF FIAT PUNTO GRANDE 2008? 735446970 FA646170237141 Thanks in advance! |
Silver Member Username: Titanum123Post Number: 729 Registered: Oct-13 | huron12 New member Username: Huron12 Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet |
New member Username: Huron12Post Number: 2 Registered: Oct-14 | Gracias de todos modos. Mi ingles es muy malo. many Thanks |
New member Username: Shema1991Post Number: 1 Registered: Oct-14 | Hi can somebody help me please, I need the radio code for my fiat punto; BP937227253416 BP Nr 7 649 372 316 Thank you very much. Ivan |
New member Username: TetleyBrumUk Post Number: 1 Registered: Oct-14 | hi can anyone help with a Blaupunkt radio code for a Fiat Punto not sure which numbers you need: BP237536875586 stamped on right side 8 635 123 208.2 stamped on left side 8 635 123 436 stamped on rear panel bar code sticker 509 2008 1614 many thanks for any help with this |
Silver Member Username: IwosPost Number: 315 Registered: Jul-14 | gary1969g New member Username: Tetley Hi, try code .. 5116 |
Gold Member Username: DeksterPOLAND Post Number: 1939 Registered: Sep-12 | Shema CODE 6411 contact me: http://koddoradia.pl/ |
New member Username: MaxmitomaxPost Number: 1 Registered: Oct-14 | Hi to all, Is it possible to find the code for a Blaupunkt radio: model:500 Fiat 312 black MP3? Part number/model: 7 647 389 316 / 7354524860 Serial number: BP738987112778 Thank you in advance, Max |
Silver Member Username: IwosPost Number: 316 Registered: Jul-14 | maxmitomax New member Username: Maxmitomax Hi, Try code .. 1653 |
New member Username: MaxmitomaxPost Number: 2 Registered: Oct-14 | Hi Almaida, many many thanks! the code is correct!!! max |
New member Username: BreenodonnellPost Number: 1 Registered: Oct-14 | Hi, Is it possible to find the code for my blaupunkt car radio: Im not sure what the numbers mean so I'll list them as I see them... 65220001168 fiat199 CD sb05 uncoloured vers BP-Nr 7 646 327 316 Fiat-Nr 735 429 552 0 Thanks so much in advance |
Silver Member Username: Titanum123Post Number: 734 Registered: Oct-13 | Breen New member Username: Breenodonnell Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casing |
New member Username: BreenodonnellPost Number: 2 Registered: Oct-14 | Spend ages looking for the serial number earlier, thanks for helping me realise it was engraved in the metal!! BP632767045759 Thanks!! |
Silver Member Username: Decode_radioPost Number: 373 Registered: Jan-14 | Breen New member Username: Breenodonnell CODE 4522 contakt me http://forum.kody-radio.pl |
New member Username: TetleyBrumUk Post Number: 2 Registered: Oct-14 | ALMAIDA Silver Member Username: Iwos Post Number: 315 Registered: Jul-14 Posted on Saturday, October 04, 2014 - 12:36 GMT gary1969g New member Username: Tetley Hi, try code .. 5116 code worked - many thanks |
New member Username: Slim64Post Number: 1 Registered: Oct-14 | Hi, I also need the code for my blaupunkt radio. Serial number: BP633565278334 Part number: 7 646 335 316 Thanks in advance. |
Silver Member Username: Titanum123Post Number: 740 Registered: Oct-13 | slim64 New member Username: Slim64 try code 5135 |
New member Username: GmurdockPost Number: 1 Registered: Oct-14 | Hi, Was looking to get the code for my stereo if possible please? Serial Number: BP237536863411 Many thanks! |
Silver Member Username: Titanum123Post Number: 743 Registered: Oct-13 | Gareth New member Username: Gmurdock try code 6312 |
Silver Member Username: IwosPost Number: 321 Registered: Jul-14 | Gareth New member Username: Gmurdock Hi, TRY CODE .. 6312 |
New member Username: GuillebacteriaPost Number: 1 Registered: Oct-14 | MODELO : 22DC259/62F TON 191 RN259FY0008025 PRODUCTO : HC0200440008025 8200029539TN191 8200 029 539 MADE IN BRAZIL Hola agradecerÃa mucho si podrÃan mandarme el código de stereo de Renault clio 2001 RN diesel. ya que no encuentro quien me ayude. desde ya muchas gracias por recibir mi mensaje y espero una pronta y favorable repuesta con el código .muchas gracias |
Silver Member Username: Titanum123Post Number: 744 Registered: Oct-13 | guille New member Username: Guillebacteria try code 2845 |
New member Username: Grg_adyBrailaRomania Post Number: 1 Registered: Oct-14 | Please help me with code for Fiat Linea My cd-player is Blaupunkt BP633789633848 7 646 337 316 Fiat D323CDTESB05 E10345501 Thank you! |
Silver Member Username: Titanum123Post Number: 745 Registered: Oct-13 | adriang New member Username: Grg_ady try code 2533 |
New member Username: BreenodonnellPost Number: 3 Registered: Oct-14 | Thanks a million!! Code worked perfectly, youre a lifesaver. |
New member Username: Grg_adyBrailaRomania Post Number: 2 Registered: Oct-14 | You are the best! Code work perfectly. Thanks. |
New member Username: CraigwhytePost Number: 1 Registered: Oct-14 | Can someone get me a code please Bp937227279265 7649372316 |
Silver Member Username: IwosPost Number: 329 Registered: Jul-14 | Craig New member Username: Craigwhyte try code .. 3416 |
New member Username: ClinPost Number: 1 Registered: Oct-14 | Could someone please help me with de code for my Fiat Punto Radio? BP937213819574 7649372316 but last digit could also be an 8, it's wrinkled... Thanks a lot! Claire |
Silver Member Username: Titanum123Post Number: 751 Registered: Oct-13 | Claire New member Username: Clin try code 3424 |
New member Username: ClinPost Number: 2 Registered: Oct-14 | It works! Thanks a lot!!! |
New member Username: Leahokeeffe1Post Number: 1 Registered: Oct-14 | Hi, radio jis asking me for code. My serial number is BP317642146068 |
Silver Member Username: Titanum123Post Number: 754 Registered: Oct-13 | Leah New member Username: Leahokeeffe1 try code 6349 |
New member Username: Leahokeeffe1Post Number: 2 Registered: Oct-14 | Sorry but I only have numbers 1-6 available |
Silver Member Username: Decode_radioPost Number: 381 Registered: Jan-14 | Leah New member Username: Leahokeeffe1 TRY CODE 5365 contakt me http://forum.kody-radio.pl |
New member Username: ThinhphuautoPost Number: 1 Registered: Oct-14 | Hi all, somebody help me, i need code for my Blaupunkt car radio, my car is BMW, year 1990 Serial number BP027340132045 part number 7640273342/40/44 |
Gold Member Username: DeksterPOLAND Post Number: 1944 Registered: Sep-12 | Thinh Phu CODE 1777 contact me: http://koddoradia.pl/ |
New member Username: ThinhphuautoPost Number: 2 Registered: Oct-14 | Thank you thank you very much! |
New member Username: Taylor89Post Number: 1 Registered: Oct-14 | Help please. Looking for a code for my punto blaupunkt radio... BP 937213865447 Other code on it is 7649372316 Much appreciated if anyone can help ! |
Silver Member Username: IwosPost Number: 334 Registered: Jul-14 | Fallon New member Username: Taylor89 TRY CODE .. 5222 |
New member Username: Taylor89Post Number: 2 Registered: Oct-14 | Worked a treat thankyou !! Much appreciated. |
New member Username: RámboHannover Post Number: 1 Registered: Oct-14 | BP9372y1119777} |
Gold Member Username: DeksterPOLAND Post Number: 1946 Registered: Sep-12 | Rámbo CODE 6412 contact me: http://koddoradia.pl/ |
New member Username: RámboHannover Post Number: 2 Registered: Oct-14 | thank you it worked |
New member Username: DoddinsPost Number: 1 Registered: Oct-14 | Hi I need a code for my Blaupunkt Punto radio Serial no BP237547042593. Part no 7642375316. Thanks a lot if you can help I would be most grateful |
Silver Member Username: Decode_radioPost Number: 383 Registered: Jan-14 | Rachel New member Username: Doddins CODE 2436 contakt me http://forum.kody-radio.pl |
New member Username: DoddinsPost Number: 2 Registered: Oct-14 | Wow that worked thanks a bunch I'm so impressed 😃 much appreciated |
New member Username: SizwePost Number: 1 Registered: Oct-14 | Hi there, can I please get a code for my Fiat Punto 6v Blaupunkt Radio BP Nr 7 644 337 316 BP433740440618 |
Silver Member Username: Titanum123Post Number: 765 Registered: Oct-13 | sizwe New member Username: Sizwe try code 5232 |
New member Username: YagolmPost Number: 1 Registered: Oct-14 | My friend is the radio of continental italy punto 2011 , you could send me the cod it if I sent you the information you need ? |
Gold Member Username: DeksterPOLAND Post Number: 1948 Registered: Sep-12 | Yago Luiz Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body. contact me: http://koddoradia.pl/ |
New member Username: YagolmPost Number: 2 Registered: Oct-14 | this is the photo , I thank you . |
New member Username: ElinearzPost Number: 1 Registered: Oct-14 | Need code for Blaupunkt fiat sporting radio. All it displays is "CANCHECK" BP 237534142570 735337934 Help please!! |
Silver Member Username: IwosPost Number: 340 Registered: Jul-14 | Eli New member Username: Elinearz Try code .. 2324 |
New member Username: YagolmPost Number: 3 Registered: Oct-14 | ALMAIDA My can not you ? I thank you . |
New member Username: Louloo22Post Number: 1 Registered: Oct-14 | hia we have a Blaupunkt radio in a fiat multipla BP632565322772 7646325316 had a new battery fitted and cant find the code for the radio.. also its saying 'wait' and we have left it on for hours now..can i still enter the code normally? thanks in advance. |
Silver Member Username: Titanum123Post Number: 776 Registered: Oct-13 | linda New member Username: Louloo22 try code 5612 |
New member Username: Louloo22Post Number: 2 Registered: Oct-14 | thank you. I have never been given the code but recall being told it when we bought the vehicle 4years ago and the salesman entered it. I dont know why i didnt write it down, or did and lost it.. its been saying 'wait' for weeks..can i reset it any way? |
New member Username: Louloo22Post Number: 3 Registered: Oct-14 | ahh ive just read and it says you prob need to leave it on 24hrs..we didnt realise it was a problem trying codes and my small son sits by the radio and has been inputting so i reckon we are at the max. I guess we need to plug it in at home and try that, then try your code. Thanks again x |
New member Username: Louloo22Post Number: 4 Registered: Oct-14 | o/h has no idea how to power it up at home. I can see us buying a new radio :/ |
