Renault radio code
Username: Bikes1
Hi all
Had to change the battery on my Renault Laguna est 04 plate. Don't have the radio code can anyone help please! the kids are driving me mad!
model no RENMCC101-00
VDO no 0495027100276780
prod no FD0004490026367
another no 8200 339 742
Many thanks
Username: Dekster
POLAND
Post Number: 1846
jeff
Please, letters/numbers from the main bar code 8200xxxxtt123, 7200xxxxxtt123 or security code, as Q123 or T0U123
contact me: http://koddoradia.pl/
Username: Bikes1
Thanks for the reply
This is all that is on the radio. Have attached a photo or is there somewhere else to look for info?
regardsUpload
Username: Iwos
Post Number: 44
jeff
Username: Bikes1
hi
Bring us a picture that is visible and see if there are numbers engraved on the metallic case.
Username: Danny32
Hi I have just hanged my fuses an now my radio is askin for a code that I dnt have cud you plz help.
Model no 22dc259/62p
Tor310
Rn259f10207926
Fd04010207926.
Many thanks.
Username: Iwos
Post Number: 47
danny32
Username: Danny32
hi
TRY CODE .. 8618
Username: Kiwidan
My 04 renault scenic battery died,now radio is looking for code, pulled out the radio and got these;
model no RENRDW132-10
V941 SECURITY
RNRD0440048306
Hope someone can help me with the code
Username: Iwos
Post Number: 49
kiwidan
Username: Kiwidan
TRY CODE .. 4002
Username: Kiwidan
Thanks ALMAIDA THE CODE WORKED I HAVE THE RADIO WORKING AGAIN
Username: Bikes1
Hi Dexter and all
sorry taken me a while to check the info now found the following, which I believe was missing from my original post.
Bar code 8 200 089 153 TX 895
Serial no ALR 92S40856649
T40856649
other numbers PN MH9 RN920LC
A42
AL R92S 56649
020366
Hope you can help from this
Many thanks
Username: Cfldjamie
Having trouble getting my car Radio working after Battery change.
Got code in service book cover but that does appear to be incorrect.
In handbook it states: 6275
Any help would be much appreciated.
Thank you in advance!
Username: Iwos
Post Number: 62
Cfldjamie
Username: Cfldjamie
TRY CODE .. 8319
Username: Cfldjamie
Yes 8319 Worked.
Many thanks!
Username: Guille4191
renault megane 2000
tunerlist model: 22dc259-62t
serial 7700434422tr149
pleaseeeee!!
Username: Iwos
Post Number: 71
guillermo castro
try code 8804
it didn�t work
model: 22dc259-62t
prod number: fd0200010027743
serial: 7700434422rt149
Username: Iwos
Post Number: 72
guillermo castro
try 6808
either
Username: Sbuckle
Hi all, im new to the forum, I have just bought a
Renault Megane 2007 and need a radio code, can
anyone please help me?
the pre code is R565 it also has on the radio these
codes, 8200607918T
RNRDBE90888066
RENRDW330-10
FD0909030888066
Any help is much appreciated
thanks in advance
Username: Titanum123
Post Number: 660
sbuckle
Username: Sbuckle
try code 8408
http://www.forum-auto.com/pole-technique/equipement-automobile/sujet395936-5460. htm#t14836864
Username: Sbuckle
the code worked!
thankyou so much !!
Username: Ricbrad
hi guys looked for a working code calculator cant find one so any help on code for this stereo would be appreciated.
laguna 51 plate
model number:22DC279/62Z
PROD NUMBER:FD0101270118318
NUMBER I THINK YOU NEED:8200002607TJ113
thanks for any help.
Username: Iwos
Post Number: 114
ricbrad
Username: Ricbrad
hi,
try code .. 7782
Username: Ricbrad
ALMAIDA :::: thankyou very much worked a treat least i dont have to listen to all the groans and creeks of an old car now i owe you a pint sir.
Username: Dejan1
Hi all
Had to change the battery on my Renault Laguna 2 Don't have the radio code can anyone help please! the kids are driving me mad!
model no 22DC279/62Z
T0Z061
RN279F10108814
prod no FD0101260108814
another no 8200002607TZ061
8200 002 607
Many thanks
Username: Iwos
Post Number: 126
38236 Strpce
Username: Dejan1
Hi,
Try code .. 0977
Username: Konyo
Please Help
I need a code:
22dc259/62f
RN259f30414628
Thanks
Username: Iwos
Post Number: 135
Konyo
Username: Konyo
Username: Konyo
Username: Iwos
Post Number: 137
Konyo
Username: Konyo
Try Code .. 1686
Username: Konyo
Thanks, I will try it !
Username: Nojby1000
image/bmpUpload
Post Number: 691
Nojby1000
Username: Nojby1000
try code 1973
Username: Nojby1000
Thank you very much master Titanum123 !!
Eternal gratitude will chase !!
Username: Muldoooon
Renault Clio Dynamique 16V
Need the radio code
Model No. 22DC278/62B
Product No. FD0202030118845
Need the radio code please
Username: Dusan_dulic
MODEL NO: RENRDW100-10 PROD NO:FD0003220067038 TOS619 RNRD0130067038 8200247962TS619 8200 247 962
Username: Iwos
Post Number: 211
dusan
code .. 7353
Username: Leesimon333
Hello,I need radio code for my Renault Megane Dynamic 2005 please.Upload
Username: Iwos
Post Number: 225
Lee Simon
Hello,
Try Code .. 4838
Username: Raimis
Good evening gentlemen.
Can someone help me with code for my Laguna stereo?
Username: Iwos
Post Number: 234
Raimis
Username: Raimis
Hello,
Try Code .. 4496
Username: Gabrielferdocampo
PLEASE HELP ME,I NEED CODE
MODEL NO:22DC461/62E
FD 09 99 07 2136070
PROD NO:FD 0999072136070
THANKS
Username: Regrooster
Post Number: 11744
#Gabrielferdocampo
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Radio removal instructions can be found here
http://www.fitaudio.com/
Username: Iwos
Post Number: 259
gabrielferdocampo
7700 433 074 Y273
Post Number: 11750
#Gabrielferdocampo
Try code 1750
THANK YOU VERY MUCH
Username: Jesky
Username: Dejan1
Posted on Sunday, August 24, 2014 - 13:23 GMT
Hi all
model no: RENRDW100-10
Z414
RNRD0140181181
prod no: FD0404170181181
another no: 8200247962TZ414
8200 247 962 --B
Many thanks
Username: Iwos
Post Number: 307
jesky
Username: Jesky
HI,
TRY CODE .. 0567
Username: Jesky
Your code does not, and the radio code is 7962 but it also fails
Username: Jesky
code 0567 is incorrect, some other code?
Username: Paul42
Telšiai, Select One Lietuva
Hello, please help with the security code:
Megane 2003; MODEL No: 22DC277/62
TR768
RN277F30299337
PROD NO:FD0303410299337
Username: Decode_radio
Post Number: 369
Paul442
Username: Paul42
CODE 8251
contakt me http://forum.kody-radio.pl
Username: Jesky
code 0567 is correct, I am not well confirmed code, thank you.
Username: Mosesmtryahoocom
Hi all,
I removed the battery of my renault megan 2008 model and now the radio is requesting for a code.
the numbers on my car radio are as follows:
Serial No.: RNRDBE70282160
Security number: W978
Please help me to restore my music. Thanks in advance a Million times.
Regards
Post Number: 737
moses matare
try code 3094
Hello,I need radio code foe my Renault Grand Scenic pleaseUpload
Username: Iwos
Post Number: 324
Lee Simon
HI,
TRY CODE .. 4297
Post Number: 748
Lee Simon
try code 4297
Yes correct,thanks so much.Now the children can enjoy their music again.You've just put a smile on someone's face.
Thanks alot
Username: Littlefish
Hi. I just changed the stereo surround for my megane but had to disconnect the radio, now it's asking for my code, can anyone help me please.
Model number: 22DC277/62
TOC355
RN277F30209766
Prod no: FD0103240209766
8200256141TC355
Thanks
Post Number: 761
Littlefish
try code 0664
Thank you so much. Really appreciate that.
Username: Engelahurter
Hi there
Need radio code for megane.
Info as follow:
Model nr: 22dc277/62
Prod nr: fd0303390292605
Serial nr: 8200256141tm142
Post Number: 772
engela hurter
try code 1714
Thank you very much. Code is 100%
