New member Username: Pearls1Post Number: 1 Registered: Oct-14 | Looking for an unlock code on the following head unit. Here's the only markings that I see: BMW CM 5903. A20910405. This is a radio/cassette from early 90's 3 series. |
Silver Member Username: Decode_radioPost Number: 382 Registered: Jan-14 | serial numbers from radio please contakt me http://forum.kody-radio.pl |
New member Username: Pearls1Post Number: 2 Registered: Oct-14 | The only other marking is: 88 88 1 600 267 Would this be the serial number? |
Gold Member Username: DeksterPOLAND Post Number: 1947 Registered: Sep-12 | Richard Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body. contact me: http://koddoradia.pl/ |
Platinum Member Username: RegroosterPost Number: 11760 Registered: Aug-08 | The CM5903 is an older radio using a different security system and so the code is not calculated using the Serial Number. It will require further technical advice Try emailing here restoredclassic@aol.com and they should be able to help as I know they have provided others with these old BMW radio codes Mention this Forum |
