New member Username: EurowerksPost Number: 1 Registered: Aug-14 | Hello I just bought an old Jag and the stereo is missing the code. Serial 47003482 B73203693 It's an old deck and any help is appreciated. Cheers, Adam |
Gold Member Username: DeksterPOLAND Post Number: 1884 Registered: Sep-12 | Adam Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casing contact me: http://koddoradia.pl/ |
New member Username: EurowerksPost Number: 2 Registered: Aug-14 | Ok will do today. Thanks |
New member Username: EurowerksPost Number: 3 Registered: Aug-14 | Where is the stamping on the metal case |
New member Username: EurowerksPost Number: 4 Registered: Aug-14 | Sorry it's b473203692 |
Platinum Member Username: RegroosterPost Number: 11739 Registered: Aug-08 | Is Louis CM41 the correct name as there are two similar names listed in the BP database...and one is Non-Coded http://codedradio.info/?i=bn&st=louis |
New member Username: EurowerksPost Number: 5 Registered: Aug-14 | Louisville cm41 |
Platinum Member Username: RegroosterPost Number: 11740 Registered: Aug-08 | Louisville cm41 This is an old BP model that cannot be decoded using the Serial Number . I believe it is a version that uses soldered jumpers on the PCB for its code so it will have to be decoded by a specialist BP Decoding Service . If it is essential that you want to get this old radio working ( for authentic classic car reasons )then you could try emailing restoredclassic@aol.com to see if they can help as I know that others on these Forums have been successful with them. Mention this Forum Otherwise it may be more economical to buy a working replacement radio , either a similar Blaupunkt or a modern aftermarket model (with MP3 perhaps) |
New member Username: EurowerksPost Number: 6 Registered: Aug-14 | I just picked up a later Jaguar stereo Model No. AJ8700 Serial B60914873 Any help is greatly appreciated... |
Silver Member Username: Decode_radioPost Number: 319 Registered: Jan-14 | Adam New member Username: Eurowerks sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
