Username: Astragsigsi Aalborg,
Nordjysk
Denmark
Post Number: 3 Registered: Aug-14
Saturday, August 23, 2014 - 13:06 GMT Hi. Need code for Blaupunkt Audi Concept (Audi A3 2006 yr.) Model Nr: 7647253380 Serial Nr: AUZ1Z3G9073622 Thanks in advance!!!
Username: Iwos Post Number: 116 Registered: Jul-14
Saturday, August 23, 2014 - 13:25 GMT Dimitar New member Username: Astragsigsi Hi, Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet
Nordjysk
Denmark
Post Number: 5 Registered: Aug-14
Saturday, August 23, 2014 - 13:57 GMT Is there anything left I could try or do on the internet? What is the procedure with decoding because there are no buttons with numbers? Thank you!
Username: Iwos Post Number: 118 Registered: Jul-14
Saturday, August 23, 2014 - 14:12 GMT Dimitar New member Username: Astragsigsi Code Entry as Follows: Switch Radio On - Display Shows " SAFE " and then shows " 1000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press "ENTER" to Enter And the Radio will then turn On
