Code Alfa
Username: Bugg75ts
i need code for this radio please
thank you
Username: Titanum123
Post Number: 429
bugg
Username: Bugg75ts
Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casing
Username: Bugg75ts
I have just this code. I've not an other.
Username: Bugg75ts
BP937817265192
Username: Dekster
POLAND
Post Number: 1589
bugg
Username: Bugg75ts
CODE 1615
contact me: http://koddoradia.pl/
Username: Milou
Salut !
Je souhaiterais avoir le code de cet autoradio (Alfa 147) :
- BP - Nr : 7 649 378 316
- Prod. Nr. Fiat : 735 293 234
- N� 9 635 123 208.2
- N� chassis : ZAR93700003067099
Merci beaucoup
Username: Dekster
POLAND
Post Number: 1638
Milou
Username: Milou
Post the 14 character Serial Number beginning BPXxxxxxxxxxxx found stamped in the metal casing
Username: Milou
BP937817310497
Username: Dekster
POLAND
Post Number: 1639
Milou
Username: Milou
CODE 1511
Username: Pasu
Salut !
Blaupunkt : 815BP5327575480116
D'avance Merci
Username: Decode_radio
Post Number: 210
UHLRICH Pascal
Username: Pasu
Post the 14 character Serial Number beginning BPxxxxxxxxxxxx found stamped in the metal casing
contakt me http://forum.kody-radio.pl
Username: Pasu
BP-Nr. 7 645 327 316
Username: Pasu
Salut !
Blaupunkt : BP5327575480116
D'avance Merci
Username: Milou
ça fonctionne ! Merci beaucoup ! =)
Username: Pasu
rrrrr
now is good ... sorry
Salut !
Blaupunkt : BP532757548116
D'avance Merci
Post Number: 482
UHLRICH Pascal
Username: Pasu
try 1522
Username: Pasu
Titanum123, Thank you very much for your great cooperation
Username: Zougzoug33
Bonjour � tous,je souhaiterais obtenir le code svp:bp-nr.7643301316 prod.nr.fiat 156053469 merci d'avance
Rebonjour sinon j'ai ce code ci:815BP330147439523 et merci beaucoup � celui qui m'aidera
Post Number: 485
fab
try code 2251
merci qwerty
Username: Lory
PLS HELP
becker siemens on alfa 166
serial no. ar2070030819/01
2580G60Y5035068
BE2580
I NEED CODE THANKS
Username: Dekster
POLAND
Post Number: 1696
lory
Username: Lory
This unit requires 2 codes..a Siemens and a Becker
See your PM message
Username: Lory
where you told me to contact you is a language i dont understand how can we talk
Username: Lory
pls help me what are the codes the system tells me is 4 figure code
