New member Username: Andreidrive1984Post Number: 2 Registered: May-14 | hello , I had to change the battery to my Peugeot last week and I don't have the code for the radio, can you help me out pu2294a model cl040151020722c serial number many thanks ! |
Gold Member Username: DeksterPOLAND Post Number: 1643 Registered: Sep-12 | MIHAI-ANDREI New member Username: Andreidrive1984 Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contact me: http://koddoradia.pl/ |
New member Username: Andreidrive1984Post Number: 3 Registered: May-14 | hello again , I got the serial number that starts with c70000005325 thank you again for you response |
Gold Member Username: DeksterPOLAND Post Number: 1645 Registered: Sep-12 | MIHAI-ANDREI New member Username: Andreidrive1984 CODE 6553 contact me: http://koddoradia.pl/ |
New member Username: Andreidrive1984Post Number: 4 Registered: May-14 | thank you ever so much for your help |
