New member Username: Mwza296Post Number: 1 Registered: Feb-14 | Kindly provide a radio code for Blaupunkt radio fitted on an Alfa 147. The serial number is as follows:BP439251241263 and the part number is:7 644 392 316 Regards Andrew Maseko |
Gold Member Username: OpelopPost Number: 2325 Registered: Sep-12 | CODE 1332 contakt me http://forum.kody-radio.pl |
Bronze Member Username: Chopper61Kirkcaldy, Fife United Kingdom Post Number: 23 Registered: Feb-12 | Hi hope you can help just bought a ford fiesta put new battery in but discoverd didn't get code with it can't get radio out but can see some numbers they are fd4500 also mo79489. And end260345 hope you can help |
Bronze Member Username: Decode_radioPost Number: 21 Registered: Jan-14 | dmg Bronze Member Username: Chopper61 one code request every 6 months minimum |
New member Username: DmoriPost Number: 1 Registered: Apr-14 | I have 2004 ford explorer and need the cd player code s_num m008782 |
New member Username: AkamaPost Number: 2 Registered: Mar-14 | 9471 code for m008782 |
New member Username: DidododyPost Number: 1 Registered: Apr-14 | help needed code for grundig sc 303 c GME303W1079034 thank you |
New member Username: BitterPost Number: 1 Registered: Apr-14 | Hello. I have a Mercedes ML270 CDi 2000 model. Replaced battery. Forgot that I do not have code for radio! Vin no is WDC1631132X718738. Can somebody please help? |
Silver Member Username: Titanum123Post Number: 396 Registered: Oct-13 | Bitter New member Username: Bitter try code 13425 |
Silver Member Username: Titanum123Post Number: 397 Registered: Oct-13 | didodody New member Username: Didodody Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet |
New member Username: Patrick81Post Number: 1 Registered: Apr-14 | I wonder could you help me to get my radio up and running again Renault magane t787 hope you can help |
New member Username: Patrick81Post Number: 2 Registered: Apr-14 | should be t787 |
Gold Member Username: DeksterPOLAND Post Number: 1535 Registered: Sep-12 | patrick81 New member Username: Patrick81 CODE 6288 contact me: http://koddoradia.pl/ |
New member Username: Bluex48Post Number: 1 Registered: Apr-14 | hi, just bought a opel corsa with a delco cdr 500 sn: GM1500Y9294313 , can u help me with a unlock code ?! thnx, |
Gold Member Username: DeksterPOLAND Post Number: 1539 Registered: Sep-12 | david New member Username: Bluex48 CODE 1781 contact me: http://koddoradia.pl/ |
New member Username: ThebluecubePost Number: 1 Registered: Apr-14 | Hi, I've changed the battery on my Peugeot diesel & I can't find the code to re-set my Clarion CD/Radio. It's model number: PU-2294A© Serial number:CL040130853060 Is this enough information for someone on the forum to be able to give me the code I need.? Hope so.!! Thanks. |
Bronze Member Username: Decode_radioPost Number: 67 Registered: Jan-14 | TheCube New member Username: Thebluecube Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
New member Username: ThebluecubePost Number: 2 Registered: Apr-14 | Unfortunately, it hasn't got the C 7000000 serial number. Many thanks for your help. |
New member Username: Rebel01Post Number: 1 Registered: Apr-14 | Hi I need a radio code for a skoda octvia please |
Silver Member Username: Titanum123Post Number: 404 Registered: Oct-13 | Becky New member Username: Rebel01 Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet |
New member Username: JaywalkerPost Number: 1 Registered: Apr-14 | I have a PU-2294A© and need the code for it. *C70000005311* Thanks in advance! |
Bronze Member Username: Decode_radioPost Number: 78 Registered: Jan-14 | Jarmo V��is��nen New member Username: Jaywalker CODE 6545 contakt me http://forum.kody-radio.pl |
New member Username: Carlito7PA USA Post Number: 3 Registered: Apr-14 | BLUPUPUNKT Radio Serial: AUZ1Z6T8226783 Model: 7 646 894 380 Please provide code Thank You in advance |
Bronze Member Username: Decode_radioPost Number: 81 Registered: Jan-14 | Carlitos New member Username: Carlito7 sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: SixpencePost Number: 1 Registered: Apr-14 | hello, I have a DELCO ELECTRONICS, type CDR 500(D), No: 90566821, GM0500V9247602, and need the code for it. Thank you in advance |
Gold Member Username: DeksterPOLAND Post Number: 1553 Registered: Sep-12 | sixpence New member Username: Sixpence Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet contact me: http://koddoradia.pl/ |
New member Username: SixpencePost Number: 2 Registered: Apr-14 | ty dekster |
