New member Username: Liverpool01Post Number: 1 Registered: Apr-14 | Hi i need a code for my radio if anyone can help me please the serial number for the radio is below any help would be really welcomeing thank you in advance sn:CL040210630177 |
Bronze Member Username: Decode_radioPost Number: 62 Registered: Jan-14 | Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
