Ford mondeo cd6 code
Username: Naishdh
Hi all. I need the code for my MondeoSony head unit that came with the car I just got from auction. details are:-
Serial # V002360
Model CD307-CD6
Sony item # CDX-FC307FE
These were the numbers off the label on the side of the unit. Please can anybody help? Thanks
Username: Regrooster
Post Number: 11692
FORD V SERIAL NUMBER CODES
If your radio has the Ford V Serial Number then it will not normally be available for free as access is required to the Ford factory database (unless you can blag it for free from Ford)
A recommended cheap and reliable place is here
www.ukbookshelf.co.uk/fordv
Mention this Forum
Otherwise try your Ford Dealer or a Radio Decoding Service
