New member Username: GuitarleePost Number: 1 Registered: Mar-14 | Just bought a 306 w-reg estate need a new battery at the weekend now code is needed help Serial: CL0401Y0104009 PU-2294A Any help most appreciated |
Platinum Member Username: RegroosterPost Number: 11683 Registered: Aug-08 | #lee Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio |
Gold Member Username: OpelopPost Number: 2428 Registered: Sep-12 | Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
New member Username: Dandylion30Post Number: 1 Registered: Mar-14 | }hi there can anyone help me with my radio ive let the battery go flat and cant find code peugeot expert 2006 number is pu2294a c70000006413 |
Gold Member Username: OpelopPost Number: 2429 Registered: Sep-12 | brian New member Username: Dandylion30 CODE 1641 contakt me http://forum.kody-radio.pl |
