UNLOCK CODE BMW 1987
Username: Mikirodriguez
Hi, I need the unlock code for my BMW 1987 RADIO SERIAL:f71128463 a
Username: Titanum123
Post Number: 358
MIGUEL RODRIGUEZ
Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body. To remove the radio can be found here: http://www.fitaudio.com/index.php?CategoryID=4
I've already removed the radio, I just need de security code for my BMW E30 RADIO SERIAL:f71128463 a
Username: Regrooster
Post Number: 11685
These older BMW radio codes often cannot be calculated using the Serial Number because they use a solder tag system for their codes so will require further technical advice
Try emailing
restoredclassic@aol.com
to see if they can help
Otherwise a BMW Dealer or a Radio Decoding Service only to get it decoded
