New member Username: JjcdPost Number: 1 Registered: Mar-14 | Hi all, I changed the spark plugs (disconnected battery)so need to enter the code for my radio)! I am aware it may not be possible for anyone to help get my code as I do not have a definite C7000000xxxx number. However what I do have is as follows: Model: PU-2294A© Number: CL0401Z0489797 Another number (?): H0 1222 01 C Does this mean the C7000000xxxx number is: C70000001222? There is also a hand written number which is 570700 but I do not know if this is useful. Thank you very much for any help/advice in advance, Jonathan |
Gold Member Username: OpelopPost Number: 2421 Registered: Sep-12 | Jonathan New member Username: Jjcd CODE 2456 contakt me http://forum.kody-radio.pl |
Gold Member Username: DeksterPOLAND Post Number: 1495 Registered: Sep-12 | Jonathan New member Username: Jjcd CODE 2456 contact me: http://koddoradia.pl/ |
Bronze Member Username: Decode_radioPost Number: 46 Registered: Jan-14 | Jonathan New member Username: Jjcd CODE 2456 contakt me http://sh.st/OoAC |
New member Username: JjcdPost Number: 2 Registered: Mar-14 | Wow that was fast! Thanks a lot all three of you, I'll try it and get back to you! |
