Subwoofer, Tube lengt and size?
Username: Henrikthom
Hello.
I just built a box to my subwoofer.
The Subwoofer : https://docs.sony.com/release/specs/XSL121P5_mksp.pdf
The box is 45 * 40 * 40 cm.
I used chipboard, 2,2 mm.
I want to place a tube in the speaker, how long and what radius should it have ?
Thank you
Username: Joe1234
Post Number: 1913
Sub is recommended for sealed use,will not sound nice in a ported box but anyways, a 4 inch diameter port 28 cm long would tune you to 34 Hz.
Thank you.
Would you rec. to have a sealed box? thought the sound would be deeper if i had it ported.
Username: Joe1234
Post Number: 1914
Since you already built the box, try it out, if it turns out that it doesn't sound right to you, then build the sealed.
Hey, tried out the box, it doesnt sound as exspected, was hoping for a, well deeper sound. Do i get this from building a seal ?
Username: Joe1234
Post Number: 1915
I will review the sub parameters on the manual.
Username: Joe1234
Post Number: 1916
You will never get great performance from this sub but you could try once more, I guess you meant that wood thickness is 22 milimeters, in that case to tune to 33Hz you would need to do a 40 cm (10 cm external) length port as follows:
Thank you for the good respons, I will try this out, and see if it get worse/better then before, wil write how it goes here, if anyone elsis interested
