Orion Xtr Pro 124
Username: Lance905
I Recently Bought my newest system for aroun
$700
-I bought 2 Orion xtr pro 124 ($139 each)
-Hifonics Zeus 1800.1d ($150)
-Walmart Wire kit with capacitor ($80)
-Built own box ($50 in materials)
-I Wired the subs to 1 ohm so I'm running
900 watts to each sub
-A mix of pioneer and kicker 6.5 door
speakers ($90)
-JVC Head unit ($70)
-is this system as a whole good?
-Am i over powering them?
-Looking for any other advice
Username: Joe1234
Post Number: 1884
Your subs are 500W RMS and you amp will put out 1200 true RMS 14.4 so about 500 RMS to each sub, so you are giving rated.
I see the other components to be budget as well.
If it's loud and sound decent enough for you then it's all good.
If you have any issues with it what would those be?
Username: Bobby3342
Post Number: 112
if I were you I would get a good pair of 6.5 comps, and power them with a two channel (use the back for fill)..... if you wanna go budget look at morel maximoe 6.5 129$
Username: Joe1234
Post Number: 1901
That was Lance's first and last post.
