Pu-2294a©
Username: Ardustie
Heckmondwike, West Yorkshire United Kingdom
Hi can anyone help me with a code for pu-2294a© barcode cl040130852738, my car battery went flat :/ No code in the book!!
any help would be really great!!
Thanks
Andy
Username: Titanum123
Post Number: 124
andy
Username: Ardustie
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
Username: Migti
Hi, i have a same problem, and i would like to know if i read the eeprom memory from my radio and give you the bin file, can you help me?.
the radio is clarion serial nº: CL040140947303c
and model PU-2294A©
thank you!!!
Username: Dekster
POLAND
Post Number: 1363
migti
Username: Migti
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
contact me: http://koddoradia.pl/
