New member Username: ArdustieHeckmondwike, West Yorkshire United Kingdom Post Number: 1 Registered: Dec-13 | Hi can anyone help me with a code for pu-2294a© barcode cl040130852738, my car battery went flat :/ No code in the book!! any help would be really great!! Thanks Andy |
Silver Member Username: Titanum123Post Number: 124 Registered: Oct-13 | andy New member Username: Ardustie Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. |
New member Username: MigtiPost Number: 1 Registered: Dec-13 | Hi, i have a same problem, and i would like to know if i read the eeprom memory from my radio and give you the bin file, can you help me?. the radio is clarion serial nº: CL040140947303c and model PU-2294A© thank you!!! |
Gold Member Username: DeksterPOLAND Post Number: 1363 Registered: Sep-12 | migti New member Username: Migti Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contact me: http://koddoradia.pl/ |
