New member Username: Booper
Post Number: 1 Registered: Dec-13
Posted on bonjour I can not find my radio code after a DISCONNECT batery would you help me through thank you voici mon n* type: PH7850 SERIAL/:11483116 thx franck |
Post Number: 2 Registered: Dec-13
Posted on merci pour votre collaboration |
Silver Member Username: Titanum123
Post Number: 136 Registered: Oct-13
Posted on bruchec New member Username: Booper Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet |
