Fiat / clarion pu 2294a ©
Username: G1oves
Last year I was unfortunate to blow the engine in my fiat
Scudo van and during the rebuild my battery had to be
Disconnected , and I've tried all different sites to find the code for the sterio , can anybody help.i think it's a clarion
Many thanks .
Model no : pu - 2294a©
Serial no : CL 040140945246 C
Username: Opelop
Post Number: 2141
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
contakt me http://forum.kody-radio.pl
