Ford 6000 cd v122354 i need code pls any help
Username: Roytec
hi i need code for ford 6000 cd v122354 i disconnect the battery and its with out sound help pls
Username: Titanum123
Post Number: 84
roy
Username: Roytec
Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
Otherwise try your Ford Dealer or a Radio Decoding Service
Username: Roytec
thanks for your replay i will try to contact them thanks very much
