Radio code nissan micra 2004
Username: Jusstisha
Hi
Need the radio code for nissan micra 2004 since the battery was replaced. It's a s k12 system. Couldn't get the serial no coz the radio is in built. Is there any other way..?
Thank you
Username: Titanum123
Post Number: 48
AJ
Username: Jusstisha
Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body
Username: Jusstisha
Thank you
How do I remove the radio? Don't see any screws on it!
Username: Regrooster
Post Number: 11632
try here
http://www.fitaudio.com/index.php?CategoryID=25
Username: Jusstisha
Unfortunately the website only has details till year 2002
Username: Jusstisha
hi, ive got the vin no for the car would that
help?
its sjnfbak12u1196880
thank you
Username: Opelop
Post Number: 2126
AJ
Username: Jusstisha
serial numbers from radio please
contakt me http://forum.kody-radio.pl
Username: Jusstisha
hi
serial no
BP234756424992
Post Number: 52
AJ
Username: Jusstisha
try code 3728
Username: Jusstisha
Sorry had the wrong serial number
The correct one on the sticker reads
28185 AX610 ZU-9583
Thank you
Username: Jusstisha
Post Number: 7
28185 AX610 ZU-9583
Thank you
