New member Username: Locky1Post Number: 3 Registered: Nov-13 | Hi can you help please. New battery on nissan note 2008 I don't have the code for it. Serial. CL081880026966 Model. PN3000P Thanks in advance |
Gold Member Username: DeksterPOLAND Post Number: 1300 Registered: Sep-12 | Locky New member Username: Locky1 Duplicate post....Already answered contact me: http://koddoradia.pl/ |
New member Username: Floss30Post Number: 1 Registered: Nov-13 | hi I need a car radio code pu 2325a ( b ) serial cl0410y0092234 if anyone can help that would be great thanks |
Gold Member Username: OpelopPost Number: 2063 Registered: Sep-12 | Ann Marie Allsopp New member Username: Floss30 Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
