New member Username: ShtrombergPost Number: 1 Registered: Feb-13 | Hello everybody I've lost my car radio code, could you help me please? here are the numbers: BP937838512399 Prod Nr.Fiat : 7353018230 help me please,thank you |
Silver Member Username: OpelopPost Number: 598 Registered: Sep-12 | adrian New member Username: Shtromberg CODE 6452 contakt me http://forum.kody-radio.pl |
New member Username: Columbo13012Post Number: 1 Registered: Feb-12 | Hello, I'm looking for the code for radio, thank for your help. the numbers are : BP937828346019 7649378316 Thank you |
Silver Member Username: DeksterPOLAND Post Number: 781 Registered: Sep-12 | columbo New member Username: Columbo13012 CODE 5244 + IMMO contact me http://koddoradia.pl/ |
New member Username: CeddlabombPost Number: 1 Registered: Mar-13 | Hello, For my Alfa147: I'm looking for the code for radio, thank for your help. the numbers are : BP-nr : 7 643 301 316 Fiat : 156 053 469 Thanks for your help. Cedric. |
Silver Member Username: OpelopPost Number: 673 Registered: Sep-12 | Post the 14 character Serial Number beginning GMxxxxxxxxxxxx found stamped in the metal casing contakt me http://forum.kody-radio.pl |
New member Username: CeddlabombPost Number: 2 Registered: Mar-13 | Thank you for your answer. No. noted only on the housing is: BP330147436581 |
Silver Member Username: OpelopPost Number: 674 Registered: Sep-12 | cedric New member Username: Ceddlabomb CODE 5352 contakt me http://forum.kody-radio.pl |
New member Username: Zola1992Post Number: 1 Registered: Mar-13 | Hello, For my Alfa147: I'm looking for the code for radio, thank for your help. the numbers are : ZAR93700003275988 Thanks for your help. Julien |
New member Username: Zola1992Post Number: 2 Registered: Mar-13 | Hello, For my Alfa147: I'm looking for the code for radio, thank for your help. the numbers are : ZAR93700003275988 Thanks for your help. Julien |
New member Username: KarimbaPost Number: 1 Registered: Mar-13 | Hello , Alfa 147 - imei : 500189442039560 - 735387754 - 4m+a11ece B01 Thank you ... |
Platinum Member Username: RegroosterPost Number: 11548 Registered: Aug-08 | #Karimba ...Alfa The correct radio SERIAL NUMBER is required for a code First remove the radio from the dashboard. Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing. This information can then be used to see if a code can be calculated |
Platinum Member Username: RegroosterPost Number: 11549 Registered: Aug-08 | #Julien....Alfa The correct radio SERIAL NUMBER is required for a code First remove the radio from the dashboard. Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing. This information can then be used to see if a code can be calculated |
New member Username: RomeodasilvPost Number: 2 Registered: Apr-13 | Hello I've a same problem to my car radio code, could you help me please? here are the numbers: BP330158376116 Nr.Fiat : 156053469 help me please,thank you |
Silver Member Username: OpelopPost Number: 954 Registered: Sep-12 | romeo New member Username: Romeodasilv CODE 5214 contakt me http://forum.kody-radio.pl |
New member Username: RomeodasilvPost Number: 8 Registered: Apr-13 | thanks a lot opelop you are the best thank, thanks |
New member Username: KarimbaPost Number: 2 Registered: Mar-13 | Hello ' Alfa 147 - imei : 500189442039560 - 554550004200-00 - ba04t9c4 - simbox ducato - 554550003704 - operator : 301 - data : 3494 - s/n oo1 -------- thanks you -------- |
Silver Member Username: OpelopPost Number: 971 Registered: Sep-12 | Karimba New member Username: Karimba sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: BidouilleurPost Number: 1 Registered: Apr-13 | Hello, I've not my car radio code with my Alfa. Can you help me? BP669487405622 7 646 694 316 Thank you |
Silver Member Username: OpelopPost Number: 972 Registered: Sep-12 | Bidouilleur New member Username: Bidouilleur TRY CODE 2163 contakt me http://forum.kody-radio.pl |
New member Username: KarimbaPost Number: 3 Registered: Mar-13 | Hello , Alfa 147 554550004200-00 |
Platinum Member Username: RegroosterPost Number: 11560 Registered: Aug-08 | Karimba New member Username: Karimba The correct radio SERIAL NUMBER is required for a code First remove the radio from the dashboard. Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing. This information can then be used to see if a code can be calculated |
New member Username: KjtouVALLET, Pays de la L... France Post Number: 1 Registered: Apr-13 | Hello, I haven't the autoradio code when il bought my Alfa 147. Here the photos of numbers : Thanks a lot |
Silver Member Username: DeksterPOLAND Post Number: 843 Registered: Sep-12 | MarcNew member Username: Kjtou Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet contact me http://koddoradia.pl/ |
New member Username: FrukyPost Number: 3 Registered: Apr-13 | Hello I've not my car radio code with my alfa 147 CAN you help me? BP669476542710 7 646 694 316 Thanks so much |
Gold Member Username: OpelopPost Number: 1004 Registered: Sep-12 | Fruky New member Username: Fruky CODE 3553 contakt me http://forum.kody-radio.pl |
New member Username: FrukyPost Number: 4 Registered: Apr-13 | Thanks you my friend your are the king |
New member Username: Fab24100Post Number: 1 Registered: Apr-13 | bonjour mon num�ro de serie est le suivant: 735387753 4M-A097AE imei : 500189442031040 en vous remerciant.. |
Gold Member Username: OpelopPost Number: 1073 Registered: Sep-12 | fab24100 New member Username: Fab24100 sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: Gokhan61Post Number: 1 Registered: Apr-13 | bonjour j'aimerais avoir mon code d'autoradio de ma alfa 147 svp BP532852757967 7645328316 1560484100 merci d'avance |
Gold Member Username: OpelopPost Number: 1099 Registered: Sep-12 | gogo61 New member Username: Gokhan61 CODE 6454 contakt me http://forum.kody-radio.pl |
New member Username: Columbo13012Post Number: 2 Registered: Feb-12 | Hello, could you help me : 735 293 234 BP 7 649 378 316 Thanks |
Gold Member Username: OpelopPost Number: 1129 Registered: Sep-12 | columbo New member Username: Columbo13012 Post the 14 character Serial Number beginning BPxxxxxxxxxxxx found stamped in the metal casing contakt me http://forum.kody-radio.pl |
New member Username: Chrissy33Post Number: 2 Registered: Feb-13 | hi just brought my alfa and it needs the radio code hope someone can help me out. b937517304215 735 293 234 thanks chrissy |
Gold Member Username: OpelopPost Number: 1130 Registered: Sep-12 | chrissyxx New member Username: Chrissy33 BP9378X1234567 search something like this contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 882 Registered: Sep-12 | chrissyxx New member Username: Chrissy33 http://www.davidsonelectronics.co.uk/serial_locate.htm contact me http://koddoradia.pl/ |
New member Username: Columbo13012Post Number: 3 Registered: Feb-12 | Hello again, so the number are : BP7649378316 735293234 BP937817576317 Best regards |
Gold Member Username: OpelopPost Number: 1131 Registered: Sep-12 | columbo New member Username: Columbo13012 CODE 4113 + IMMO contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 883 Registered: Sep-12 | columbo New member Username: Columbo13012 CODE 4113 + IMMO contact me http://koddoradia.pl/ |
Gold Member Username: OpelopPost Number: 1132 Registered: Sep-12 | columbo New member Username: Columbo13012 CODE 4113 + IMMO contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 884 Registered: Sep-12 | opelop Gold Member Username: Opelop THE DOCTOR |
Gold Member Username: OpelopPost Number: 1133 Registered: Sep-12 | Dekster Silver Member Username: Dekster yes to you |
New member Username: Columbo13012Post Number: 4 Registered: Feb-12 | Sorry, what do you mean by IMMO ? |
Gold Member Username: OpelopPost Number: 1134 Registered: Sep-12 | columbo New member Username: Columbo13012 - When vehicle Radio / SatNav units are protected with additional futures like IMMO protection etc., units are not installed in original cars, units are locked and showing "CANCHECK", "IMMO", "DISABLED" etc. contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 885 Registered: Sep-12 | columbo New member Username: Columbo13012 IMMO means the radio has to be electronically linked to the car's electronics. Radio only work in car with can line (original car) contact me http://koddoradia.pl/ |
New member Username: Columbo13012Post Number: 5 Registered: Feb-12 | Sorry again, I bought a used radio to install in my car. Is it possible to remove IMMO ? Thanks |
New member Username: SullyboyPost Number: 1 Registered: May-13 | hey can some1 help me out i need the code for my alfa radio i just brought it and no code. b937517304215 735 293 234 thanks mike |
Gold Member Username: OpelopPost Number: 1135 Registered: Sep-12 | sully01 New member Username: Sullyboy CODE 3143 contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 886 Registered: Sep-12 | sully01 New member Username: Sullyboy CODE 3143 contact me http://koddoradia.pl/ |
Gold Member Username: OpelopPost Number: 1136 Registered: Sep-12 | columbo New member Username: Columbo13012 yes but you must go to Decoding Service contakt me http://forum.kody-radio.pl |
New member Username: Ccwiz1Post Number: 3 Registered: May-13 | pls help me with unlock code for becker traffic pro radio s/n 25058068 model no BE4730 thanks |
Gold Member Username: OpelopPost Number: 1147 Registered: Sep-12 | ccwiz New member Username: Ccwiz1 https://www.ecoustics.com/electronics/forum/car-audio/715753.html contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 892 Registered: Sep-12 | ccwiz New member Username: Ccwiz1 https://www.ecoustics.com/electronics/forum/car-audio/715753.html contact me http://koddoradia.pl/ |
New member Username: ChivastarPost Number: 1 Registered: May-13 | bonjour j'aimerais avoir mon code autoradio svp... BP9378Y7239714 7649378316 Nr fiat 735293234 merci |
Gold Member Username: OpelopPost Number: 1150 Registered: Sep-12 | mervyn New member Username: Chivastar CODE 2564 + immo contakt me http://forum.kody-radio.pl |
New member Username: Ccwiz1Post Number: 4 Registered: May-13 | @opelop..thanks for helping but the code didnt work...whats next pls |
New member Username: Alfagt31Post Number: 1 Registered: May-13 | Bonjour, J'ai perdu mon code d'autoradio sur ma alfa 147 BP 532857627918 7 645 328 316 Fiat nr : 156 048 410 0 Merci d'avance pour votre aide |
Gold Member Username: OpelopPost Number: 1164 Registered: Sep-12 | Jam New member Username: Alfagt31 CODE 4356 contakt me http://forum.kody-radio.pl |
New member Username: Alfagt31Post Number: 2 Registered: May-13 | Merci mais �a reste bloqu� sur "CANcheck" que faire ? |
New member Username: Steve56Post Number: 1 Registered: May-13 | bonjour j ai paum� mon code d autoradio blaupunkt pour alfa gt BP-Nr : 7 646 697 316 Fiat-Nr : 156 075 078 0 Alfa937/alfa947 C1V2 CD puma 815 BP669775720059 merci |
Gold Member Username: OpelopPost Number: 1165 Registered: Sep-12 | steve56 code 1465 |
New member Username: Steve56Post Number: 2 Registered: May-13 | merci opelop ca fonctionne au poil |
New member Username: Redzone84Post Number: 1 Registered: May-13 | Hello everybody I've lost my car radio code, could you help me please? here are the numbers: alfa 147 bp : 7 649 378 316 fiat 735 293 234 thank you |
Gold Member Username: OpelopPost Number: 1169 Registered: Sep-12 | redzone84 New member Username: Redzone84 Post the 14 character Serial Number beginning BPxxxxxxxxxxxx found stamped in the metal casing contakt me http://forum.kody-radio.pl |
New member Username: Redzone84Post Number: 2 Registered: May-13 | sorry it s bp 937817303649 fiat 735 293 234 thank you |
Gold Member Username: OpelopPost Number: 1170 Registered: Sep-12 | redzone84 New member Username: Redzone84 CODE 4621 contakt me http://forum.kody-radio.pl |
New member Username: Redzone84Post Number: 3 Registered: May-13 | it s fast thank you very much |
New member Username: Gokhan61Post Number: 2 Registered: Apr-13 | bonsoir j'aimerais avoir mon code de mon poste alfa 147 svp BP937817303866 7649378316 735293234 merci d'avance |
New member Username: Gokhan61Post Number: 3 Registered: Apr-13 | désolé je me suis tromper bp 937817303866 fiat 735 293 234 |
New member Username: Gokhan61Post Number: 4 Registered: Apr-13 | bonjour jai perdu mon code de poste alfa 147 BP937817303866 Prod. Nr. Fiat 735 293 234 BP - Nr. 7 649 378 316 svp merci |
New member Username: Francky27Post Number: 1 Registered: May-13 | bonjour je viens d acheter un gps pour alfa 147 mais pas de code voici les reference : magneti marelli CE 0681 IMEI 500101110014150 735293300 C141 16RC03W3B merci de m aider |
Gold Member Username: OpelopPost Number: 1189 Registered: Sep-12 | francky27 New member Username: Francky27 sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: Francky27Post Number: 2 Registered: May-13 | je n arrive pas a allez sur http://forum.kody-radio.pl pouvez vous m aider merci |
New member Username: Gokhan61Post Number: 5 Registered: Apr-13 | bonjour jai perdu mon code de poste alfa 147 BP937817303866 Prod. Nr. Fiat 735 293 234 BP - Nr. 7 649 378 316 svp merci |
Gold Member Username: OpelopPost Number: 1196 Registered: Sep-12 | gogo61 New member Username: Gokhan61 CODE 4222 contakt me http://forum.kody-radio.pl |
Gold Member Username: OpelopPost Number: 1198 Registered: Sep-12 | gogo61 New member Username: Gokhan61 CODE 4222 contakt me http://forum.kody-radio.pl |
New member Username: Dantes_95Post Number: 1 Registered: May-13 | Hello everybody I've lost my car radio code, could you help me please? here are the numbers: ALFA 147 BP 937817581224 FIAT 735 293 234 thank you |
Silver Member Username: DeksterPOLAND Post Number: 919 Registered: Sep-12 | Dantes 95 New member Username: Dantes_95 CODE 4526 + IMMO IMMO means the radio has to be electronically linked to the car's electronics. must go to Decoding Service contact me http://koddoradia.pl/ |
New member Username: Dantes_95Post Number: 2 Registered: May-13 | It s fast thank you |
New member Username: Nono5907Post Number: 1 Registered: May-13 | Bonjour j'ai besoin de mon code, pouvez vous me le trouvez svp? Merci Alfa 937 CD BP532757557258 Bp nr: 7 645 327 316 Fiat nr: 156 053 469 0 |
Gold Member Username: OpelopPost Number: 1225 Registered: Sep-12 | Nolan New member Username: Nono5907 CODE 4331 contakt me http://forum.kody-radio.pl |
New member Username: Nono5907Post Number: 2 Registered: May-13 | Merci beaucoup! Quel rapidit�! |
New member Username: KiwinPost Number: 2 Registered: Jun-13 | Hello, code need after power shutting Prod. Nr. Fiat 735293234 Bp937817283659 Thanks a lot! |
Bronze Member Username: Masterskay62MelitopolUkraine Post Number: 23 Registered: May-13 | Kevin New member Username: Kiwin Has already been answered. https://www.ecoustics.com/electronics/forum/car-audio/716217.html |
Gold Member Username: OpelopPost Number: 1362 Registered: Sep-12 | Kevin New member Username: Kiwin Duplicate post....Already answered contakt me http://forum.kody-radio.pl |
New member Username: MyckoulPost Number: 1 Registered: Jun-13 | Hello everybody I've lost my car radio code, could you help me please? here are the numbers: BP937817311769 Prod Nr.Fiat : 7649378316 help me please,thank you |
Gold Member Username: OpelopPost Number: 1374 Registered: Sep-12 | myckoul New member Username: Myckoul CODE 2341 contakt me http://forum.kody-radio.pl |
New member Username: Guil147Post Number: 1 Registered: Jun-13 | Hello! I'm looking for the code for radio, thank for your help. the numbers are : BP Nr 7 649 378 816 Prod Nr Fiat 735 293 234 : D |
Gold Member Username: OpelopPost Number: 1392 Registered: Sep-12 | Guil New member Username: Guil147 Post the 14 character Serial Number beginning BPxxxxxxxxxxxx found stamped in the metal casing contakt me http://forum.kody-radio.pl |
New member Username: MohwzPost Number: 1 Registered: Jun-13 | Dear alfisti....my name is wan and I havee lost my radio code for my 147 The serial no is BP93792319914 BP-NR 7649379316 Prod Nr Fiat 7353143100 Hope you guys can help me and very much appreciated Regards |
Gold Member Username: OpelopPost Number: 1397 Registered: Sep-12 | Wzmy New member Username: Mohwz Post the 14 character Serial Number beginning GMxxxxxxxxxxxx found stamped in the metal casing contakt me http://forum.kody-radio.pl |
New member Username: Guil147Post Number: 2 Registered: Jun-13 | Oups ... the numbers are : BP Nr 7 649 378 816 BP 937817304692 Prod Nr Fiat 735 293 234 |
Gold Member Username: OpelopPost Number: 1398 Registered: Sep-12 | Guil New member Username: Guil147 CODE 3354 contakt me http://forum.kody-radio.pl |
New member Username: MohwzPost Number: 2 Registered: Jun-13 | Dear admin..I am Wan and posted u my relevant info abt my car radio on june 18..just wondering if u guys can help me..tq |
New member Username: PeppitoBruxelles Post Number: 1 Registered: Jun-13 | Bonjour Je cherche le code pour la radio, merci pour votre aide les chiffres sont: BP937817298473 Prod Nr Fiat 735 293 234 Merci |
Gold Member Username: OpelopPost Number: 1403 Registered: Sep-12 | Filippo Troia New member Username: Peppito CODE 3413 contakt me http://forum.kody-radio.pl |
Gold Member Username: DeksterPOLAND Post Number: 1037 Registered: Sep-12 | Filippo Troia New member Username: Peppito CODE 3413 + IMMO IMMO means the radio has to be electronically linked to the car's electronics, contact me http://koddoradia.pl/ |
New member Username: Jb27Post Number: 1 Registered: Jun-13 | Bonjour, j'ai acheté un autoradio d'Alfa GT en casse automobile, pour mettre dans ma 147, achetée sans poste, mais je n'ai pas le code. Pouvez vous me le fournir, ou dois je aller chez Alfa ? Blaupunkt GMBH 815BP532868127597 Alfa 937 CD MP3 7 645 328 316 e1 022330 Merci |
Gold Member Username: OpelopPost Number: 1412 Registered: Sep-12 | Besnard New member Username: Jb27 CODE 5363 contakt me http://forum.kody-radio.pl |
New member Username: Lohenn26Bourg-les-ValenceFrance Post Number: 1 Registered: Jul-13 | hi , i need a code for my blaukpunt alfa147 bp937838515456 nrfiat 7353018230 |
Gold Member Username: OpelopPost Number: 1541 Registered: Sep-12 | lohenn26 New member Username: Lohenn26 CODE 4323 contakt me http://forum.kody-radio.pl |
New member Username: Lohenn26Bourg-les-ValenceFrance Post Number: 2 Registered: Jul-13 | hi thx , i need a new code for a nav magnetti mirelli imei 500101111070640 735329871 |
Gold Member Username: OpelopPost Number: 1546 Registered: Sep-12 | sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: VomaaFrance Post Number: 1 Registered: Jul-13 | Hi , i need a code for my blaukpunt alfa147� BP- Nr. 7 646 694 316 Fiat-Nr. 156 074 554 0 BLAUPUNKT GMBH 815 BP669487411427 �e1 034501 Thank you |
Gold Member Username: OpelopPost Number: 1563 Registered: Sep-12 | Maxime Vincent New member Username: Vomaa CODE 6521 contakt me http://forum.kody-radio.pl |
New member Username: Abarth11588Post Number: 1 Registered: Jul-13 | Hello everybody I've lost my car radio code, could you help me please? here are the numbers: BP7644392316 Prod Nr.Fiat : 156048410 help me please,thank you |
Gold Member Username: OpelopPost Number: 1579 Registered: Sep-12 | Max New member Username: Abarth11588 all serial numbers from radio please contakt me http://forum.kody-radio.pl |
New member Username: Abarth11588Post Number: 2 Registered: Jul-13 | bp-nr 7 644 392 316 fiat nr 156 048 410 thank |
New member Username: Abarth11588Post Number: 3 Registered: Jul-13 | bp-nr 7 644 392 316 fiat nr 156 048 410 alfa 937 cd mp3 7 644 392 316 made in portugal 815bp439251240331 very very thanks |
Gold Member Username: OpelopPost Number: 1580 Registered: Sep-12 | Max New member Username: Abarth11588 CODE 6664 contakt me http://forum.kody-radio.pl |
New member Username: Abarth11588Post Number: 4 Registered: Jul-13 | you are the best thank you |
New member Username: Abarth11588Post Number: 6 Registered: Jul-13 | you are the best thank you |
New member Username: LamichapuisPost Number: 1 Registered: Jul-13 | Hello everybody I've lost my car radio code, could you help me please? here are the numbers: BP9376Y7059115 Prod Nr.Fiat : 8 631 122 613 help me please,thank you |
Gold Member Username: DeksterPOLAND Post Number: 1123 Registered: Sep-12 | Jason New member Username: Lamichapuis CODE 6242 + IMMO IMMO means the radio has to be electronically linked to the car's electronics. CONTACT me http://koddoradia.pl/ |
New member Username: Batman2776Post Number: 1 Registered: Aug-13 | hello sorry for my english but i m french i need help for my alfa 147 connect nav+ dxm-1620 s/no.P0600615 imei 500101110134400 ce 0681 735329871 1+sc1n9ac c141 big thanks |
Gold Member Username: OpelopPost Number: 1619 Registered: Sep-12 | baptiste New member Username: Batman2776 sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: LamichapuisPost Number: 2 Registered: Jul-13 | Hello everybody I've lost my car radio code, could you help me please? here are the numbers: BP 7 649 378 316 Prod Nr.Fiat : 735 293 234 help me please,thank you |
Gold Member Username: OpelopPost Number: 1745 Registered: Sep-12 | Post the 14 character Serial Number beginning GMxxxxxxxxxxxx found stamped in the metal casing |
New member Username: LamichapuisPost Number: 3 Registered: Jul-13 | Hello everybody I've lost my car radio code, could you help me please? here are the numbers: BP 937817582724 Prod Nr.Fiat : 8 631 122 613 help me please,thank you |
Bronze Member Username: Masterskay62MelitopolUkraine Post Number: 63 Registered: May-13 | Jason New member Username: Lamichapuis Try code 4523 |
New member Username: ApericubePost Number: 1 Registered: Sep-13 | Bonjour, Auriez-vous le code pour le mod�le suivant? BP Nr 7643303316 Prod Nr 156053471 BP 330342967621 Merci d'avance. |
Gold Member Username: OpelopPost Number: 1758 Registered: Sep-12 | Apericube New member Username: Apericube CODE 1266 contakt me http://forum.kody-radio.pl |
New member Username: NonooPost Number: 1 Registered: Sep-13 | Hello, I've lost my car radio code, could you help me please? Here are the numbers: Thanks! |
Gold Member Username: OpelopPost Number: 1835 Registered: Sep-12 | Nonoo New member Username: Nonoo sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: RasorPost Number: 1 Registered: Sep-13 | Hello I've lost my car radio code, could you help me please? Becker online pro 7800 BE7800 65099616 help me please,thank you! |
Gold Member Username: OpelopPost Number: 1838 Registered: Sep-12 | zdravko New member Username: Rasor CODE 45131 contakt me http://forum.kody-radio.pl |
New member Username: RasorPost Number: 2 Registered: Sep-13 | CODE 45131 for member zdravko? Becker online pro |
New member Username: Tom2bPost Number: 1 Registered: Oct-13 | Bonjour, J'aimerais avoir mon code d'autoradio de mon alfa 147 svp Les num�ros sont : Bp 532 757 552 357 BP - nr 7 645 327 316 Fiat -nr 156 053 469 0 Merci d'avance |
Gold Member Username: OpelopPost Number: 1918 Registered: Sep-12 | Tommy New member Username: Tom2b CODE 6661 contakt me http://forum.kody-radio.pl |
New member Username: Tom2bPost Number: 2 Registered: Oct-13 | Merci, Pour la rapidit� et la pr�cision Trop cool |
New member Username: CherkePost Number: 1 Registered: Oct-13 | Bonjour, J'ai perdu mon code autoradio , pourriez-vous m'aider ? BP - Nr. 7 645 327 316 Fiat - Nr. 156 053 469 0 Merci d'avance Cherke |
New member Username: CherkePost Number: 2 Registered: Oct-13 | Could you help me , please ?? |
Gold Member Username: OpelopPost Number: 1988 Registered: Sep-12 | Thomas cherke New member Username: Cherke Post the 14 character Serial Number beginning BPxxxxxxxxxxxx found stamped in the metal casing contakt me http://forum.kody-radio.pl |
New member Username: CherkePost Number: 3 Registered: Oct-13 | It's : BP 532757548558 Thanks |
Gold Member Username: OpelopPost Number: 1990 Registered: Sep-12 | Thomas cherke New member Username: Cherke CODE 6241 contakt me http://forum.kody-radio.pl |
Gold Member Username: OpelopPost Number: 1991 Registered: Sep-12 | Thomas cherke New member Username: Cherke CODE 6241 contakt me http://forum.kody-radio.pl |
New member Username: CherkePost Number: 4 Registered: Oct-13 | Merci !!!!!! Merci beaucoup !!!!! C'est genial |
