I found an android app for those codes. It offered me 4 and 3.5 digit codes so I tried both, one was 0153 and the other one was 4153
So I think you are right, it should be 153. I tried the code but now its says: CODE WAIT
What should I do now? I read somewhere that I should keep the key on / drive for an hour so that the radio will reset the protocols or something? But I'm not sure, so what should I do next?
If I leave the key in the first position (so that the radio can be turned on), will it drain the battery? If yes, how long I can leave it like that, I don't want to drain the battery...
Seems like the code 153 is not working. I kept the radio on for one hour, then CODE WAIT disappeared, I could enter the code again but it displayed CODE WAIT again... What should I do? When I have waited for 1 hour, do I have to push any other buttons after entering code? Or do I enter the code and then just wait?
Please respond, I really need to get the radio working again.
It looks as though your radio has been recoded to a different number.The code is in MCU
(Blaupunkt BP 3850) Turn on the power receivers. The screen will display "CODE- - - - ". Buttons 1-2-3-4 enter the correct code by pressing each button repeatedly. When the display shows the correct code, you should press the ">" button below "FM". Receiver turns on.
Turn on the power receivers? Can you explain please, English is not my native language. What do you men by turning on the power receivers? When I start the car, the radio will turn on and there will be written CODE WAIT. If I wait one hour, it will display CODE _ _ _ (3 digits only).
