Clarion Car Radio Code
Username: Antoniaudo
hi, i hope you can help me! I solde my car whitout the Radio but with the Instruction of the Radio and the Code.
Model: DB288RUSB clarion
Serial Number: 0033778
Number on the backside is : CL 0840
2.Number on the backside is: 80033778
Username: Opelop
Post Number: 1809
udo
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
contakt me http://forum.kody-radio.pl
