New member Username: HpunicumPost Number: 1 Registered: Sep-13 | Hello everybody,! I please you to help me. i'v lost my Radio code. The serial is V 038082 Many thanks for helping hpunicum |
Gold Member Username: DeksterPOLAND Post Number: 1190 Registered: Sep-12 | HAPE New member Username: Hpunicum Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software. Otherwise try your Ford Dealer or a Radio Decoding Service contact me: http://koddoradia.pl/ |
