New member Username: Alrightnow123Post Number: 1 Registered: Sep-13 | Hi There, I would be most grateful if someone could please get me the radio code for my stereo. Battery died and it reset, can't find the code that I had written down anywhere! Model No: 22DC279/62T Part No: T0T382 Serial No: RN279FY0037437 Product No: FD0100160037437 Any assistance would be truly appreciated! Thanks, Alan |
Platinum Member Username: RegroosterPost Number: 11604 Registered: Aug-08 | try code 6652 |
New member Username: Alrightnow123Post Number: 2 Registered: Sep-13 | Hi Reg, That code didn't work. Thanks though mate. Anyone else got any suggestions? |
Platinum Member Username: RegroosterPost Number: 11605 Registered: Aug-08 | 6652 is the correct code for your radio Make sure you press the final button that stores the code ( ¬ 5 or 6) for at least 10 seconds |
New member Username: Alrightnow123Post Number: 3 Registered: Sep-13 | Really sorry for the hassle Reg, but I just tried it again and it didn't work. Any ideas what I'm doing wrong or why it might not be that code? Like the manual says, I enter the code with the thumbwheel, pressing the ¬ button each time to input the number, then it says to hold the ¬ button until you hear a a beep but CODE just re-appears meaning it hasn't worked. Sorry about this mate. |
Platinum Member Username: RegroosterPost Number: 11606 Registered: Aug-08 | perhaps your radio has been recoded to a different number? |
New member Username: Alrightnow123Post Number: 4 Registered: Sep-13 | i think that may be the case reg, bit silly whoever did that eh! my mum (who' s car it was) says it rings a bell that it was changed. why would someone do that? think we're gonna need to take it back to the garage where it was changed. really appreciate your help though mate. thanks. |
New member Username: AntheaPost Number: 1 Registered: Sep-13 | hi there can somebody help me with a radio code renault megane classic 2000 MODEL NO. 22DC461/62T PROD NO. FD 1199246113439 PHILIPS CD CHANGER CONTROL I HOPE IS ENOUGH :D thanks VICTOR |
Gold Member Username: OpelopPost Number: 1776 Registered: Sep-12 | aXis New member Username: Anthea Please, letters/numbers from the main bar code 8200xxxxtt123, 7200xxxxxtt123 or security code, as Q123 or T0U123 contakt me http://forum.kody-radio.pl |
