New member Username: UsamaPost Number: 2 Registered: Aug-13 | HI I NEED CODE FOR MY CAR RENAULT 7 648 051 592 SN / BP8051 9 0985727 281115428R SECURITY A155 THANKS |
Gold Member Username: OpelopPost Number: 1661 Registered: Sep-12 | CODE 0029 contakt me http://forum.kody-radio.pl |
New member Username: UsamaPost Number: 3 Registered: Aug-13 | THANK YOU SO MUCH I WILL TRY IT |
New member Username: WinmartolockettPost Number: 2 Registered: Aug-13 | Hello, I need a code for Renault Scenic Privilege MODELNO: 22DC279/62P TOYO80 RN279F10264481 PROD NO: FD0301240264481 other numbers? 7700434425TY080 7700 434 425 thanks! |
Gold Member Username: OpelopPost Number: 1664 Registered: Sep-12 | winmartolockett New member Username: Winmartolockett CODE 1904 contakt me http://forum.kody-radio.pl |
New member Username: StbridesPost Number: 2 Registered: Sep-10 | I have Renault Megane for which the battery has been disconnected and I don't have the code. RADIOSAT 6010 7700 426 412 Philips 22DC459/62L 9022 21459624 FD 08.98 24 4172305 Model 22DC459/62L Prod No. FD0898244172305 7700 426 412 A660 Thanks in anticipation. |
Gold Member Username: OpelopPost Number: 1675 Registered: Sep-12 | stbrides New member Username: Stbrides CODE 0126 contakt me http://forum.kody-radio.pl |
New member Username: StbridesPost Number: 3 Registered: Sep-10 | Thanks very much, I now have a working radio. |
New member Username: AbrisHyltebruk, Sverige Post Number: 1 Registered: Aug-13 | Hello! I�m looking for the code to my Renault Megane-99. The only number I have is the id nr.VF1KA040520845015 and it�s a Philips radio inside. Is it enough or do I need some more figures. Thanks! |
Gold Member Username: OpelopPost Number: 1676 Registered: Sep-12 | Magnus New member Username: Abris serial numbers from radio please contakt me http://forum.kody-radio.pl |
New member Username: AbrisHyltebruk, Sverige Post Number: 2 Registered: Aug-13 | Hello again! Its a Philips 22DC481/62. Prod nr FD1299219186577. Radiosat 6000 7700 433 070 Thanks! |
Gold Member Username: OpelopPost Number: 1677 Registered: Sep-12 | all numbers |
New member Username: AbrisHyltebruk, Sverige Post Number: 3 Registered: Aug-13 | Hello! This is all text on the radio: Radiosat 6000 7700433070 Philips 22DC481/62 PA5, 4x15W, RDS No CD changer control 7700 433 070 T585 FD 1299219186577 Modelno 22dc481/62 Prodno FD1299219186577 |
Gold Member Username: OpelopPost Number: 1678 Registered: Sep-12 | CODE 6406 contakt me http://forum.kody-radio.pl |
New member Username: AbrisHyltebruk, Sverige Post Number: 4 Registered: Aug-13 | Thank very much!! |
New member Username: Renault4uKROMMENIE, Nederland Post Number: 1 Registered: Aug-13 | Hello, I need a code for Renault Twingo RNRDCV80004058 RENRDW302-07 BS0108350004058 8200882966T SECURITY O713 MODELNO: 22DC279/62P Many thanks! |
Gold Member Username: OpelopPost Number: 1707 Registered: Sep-12 | Greg New member Username: Renault4u CODE 1202 or 9206 contakt me http://forum.kody-radio.pl |
New member Username: Renault4uKROMMENIE, Nederland Post Number: 2 Registered: Aug-13 | Thanks for the quick response! it's works |
New member Username: GabitzzupPost Number: 1 Registered: Aug-13 | Hello Please if some one can help me i need a radio code for a philips renault model: 22dc 982/72b s/n: RN982FS1013352 Thank You! |
Gold Member Username: OpelopPost Number: 1708 Registered: Sep-12 | Gabitzzup New member Username: Gabitzzup CODE 6257 contakt me http://forum.kody-radio.pl |
Bronze Member Username: DarkervinPost Number: 14 Registered: Sep-10 | Hello, I need a code for Renault laguna MODELNO: be7412 Tip. Navigation Seria. 35003172 ec. 101 other numbers? 8200249262 Thanks. |
Bronze Member Username: Masterskay62MelitopolUkraine Post Number: 57 Registered: May-13 | dani Bronze Member Username: Darkervin Try code 1433 |
Bronze Member Username: DarkervinPost Number: 15 Registered: Sep-10 | Tenks tenks tenks |
New member Username: GabitzzupPost Number: 2 Registered: Aug-13 | Gabitzzup New member Username: Gabitzzup CODE 6257 Thank's is working fine, many many thank's. |
New member Username: Marty66Post Number: 1 Registered: Aug-13 | Hi there i bought a new battery for my 2005 renault clio and changed it now i have no idea on how to get the radio code i have looked through all the paperwork all the info off the unit is RNRD3450064715 RENRDW220-00 FD02 0505 0064715 8200409475T S767-SECURITY Any help would be very appreciated |
Gold Member Username: OpelopPost Number: 1726 Registered: Sep-12 | marty New member Username: Marty66 CODE 7287 contakt me http://forum.kody-radio.pl |
New member Username: BrosnaPost Number: 1 Registered: Aug-13 | Hi please could you get me a code for clio radio have got one in book but can't get it to work this is 6880 Model no 22DC259/62 TOM283 RN259FY0093171 Prod no FD0200290093171 Barcode 7700434436TM283 7700434436 0093171 Many thanks xxx |
Gold Member Username: OpelopPost Number: 1728 Registered: Sep-12 | CODE 1553 contakt me http://forum.kody-radio.pl |
New member Username: BrosnaPost Number: 2 Registered: Aug-13 | Many many thanks worked a treat thankyou xx |
New member Username: Marty66Post Number: 2 Registered: Aug-13 | thanks very much for trying but no luck with 7287 |
Platinum Member Username: RegroosterPost Number: 11600 Registered: Aug-08 | #marty 7287 is the correct code for the numbers given 8200409475T S767-SECURITY Check these again Also make sure you press the final button that stores the code ( ¬ 5 or 6) for at least 10 seconds |
New member Username: Marty66Post Number: 3 Registered: Aug-13 | Hi mate u were right it was the right code in my manual it says 5 to lock the code didn't work so i tried 6 and it worked so thanks very much your a life saver |
