New member Username: Dg7890Post Number: 1 Registered: Jul-13 | Hi i had to change the battery in my car recently and my radio is now asking for a code serial number: CL0401Y0308850 model number: PU2294A if someone could help would be much appreciated Thanks! |
Gold Member Username: DeksterPOLAND Post Number: 1093 Registered: Sep-12 | dg7890 New member Username: Dg7890 Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. CONTACT me http://koddoradia.pl/ |
