New member Username: Peter33321Post Number: 1 Registered: Jun-13 | Hi, I need radio code of my Peugeot 306 Radio is Blaupunkt PF3/CDC/L Serial number: BP3778S7120680 Part number: 7643778392 Thanks for help |
Gold Member Username: OpelopPost Number: 1438 Registered: Sep-12 | Peter Kazik New member Username: Peter33321 CODE 3632 or 5694 or 0549 contakt me http://forum.kody-radio.pl |
New member Username: Peter33321Post Number: 2 Registered: Jun-13 | Thanks so much 0549 is right |
New member Username: Night1Post Number: 1 Registered: Jul-13 | Hello I had to change my battery on my 206 last week, and now I'm being asked for the radio code! Could please help me find it? It's a Clarion radio SN: CL0410Z0140032 PU 2325 A Thank you so much JM |
Gold Member Username: DeksterPOLAND Post Number: 1074 Registered: Sep-12 | Ryan New member Username: Night1 Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. Contact me http://koddoradia.pl/ |
New member Username: Night1Post Number: 2 Registered: Jul-13 | Thanks a lot for your reply Dekster. The only other SN on the barcode is: 9639692080 Regards |
