Lost code
Username: Welshpete63
Hi, I need the code for the stereo in my clio after changing the battery, I discovered I had lost the code for it! It is a Phillips 22dc461/62e, serial number rn461fx2354578, with a smaller code of k309 if this helps. Many thanks
Pete.
Username: Opelop
Post Number: 1487
pete
CODE 5348
contakt me http://forum.kody-radio.pl
Thank you Opelop, the code was ace and all works as it should, Excellent result!
