Focus 6000CD radio code needed
Username: Cgreener23
hi,
I've just bought a ford focus from a private trader and need the radio code.
Serial is V060735
anyone help?
Username: Dekster
POLAND
Post Number: 991
FORD V SERIAL NUMBER CODES
ChrisG
If your radio has the Ford V Serial Number then it will not normally be available for free as access is required to the Ford factory database (unless you can blag it for free from Ford)
A recommended cheap and reliable place is here
www.ukbookshelf.co.uk/fordv
Otherwise try your Ford Dealer or a Radio Decoding Service
contact me
http://koddoradia.pl/
Username: Baze
Hi I have ford Ka I lost my code for radio model 6000 cd serial number mo 15109
Thank you}
Username: Dekster
POLAND
Post Number: 993
baze
Username: Baze
CODE 2082
contact me
Username: Cristidascalu77
Hi I have ford focus I lost my code for radio model 6000 cd serial number M 210094
Thank you}
Username: Opelop
Post Number: 1414
cristidascalu77
CODE 3870
contakt me http://forum.kody-radio.pl
the code is ok thank you Opelop !
Username: Vcf2013
hi
I need the cod for
Radio CD Ford 6000-single CD
sn: M184956
thx
Username: Opelop
Post Number: 1425
vcf
Username: Vcf2013
CODE 3944
Username: Vcf2013
thx man
it works
