New member Username: Barringtonw2Post Number: 1 Registered: Jun-13 | Hi Guys I would be grateful if any member could give me the radio code for my 2002 Renault Scenic from the following info. Model No: 22DC258/62P Prod No: FD0102350069933 Security: TOQ635 RN258F20069933 Your help would be most appreciated. Thanks. barringtonw2 |
Bronze Member Username: Masterskay62MelitopolUkraine Post Number: 20 Registered: May-13 | barringtonw2 New member Username: Barringtonw2 Try code 9370 |
New member Username: Barringtonw2Post Number: 2 Registered: Jun-13 | Hi Masterskay62 Thanks for your very speedy reply. Will try the code as soon as "CODE" goes to 0000 to allow entry. Let you know as soon as I can enter it. Regards barringtonw2 |
Gold Member Username: DeksterPOLAND Post Number: 1009 Registered: Sep-12 | barringtonw2 New member Username: Barringtonw2 Code Entry as Follows: Switch Radio On - Display Shows " CODE " Then " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press and hold preset " 6 " To Enter Code Entry as Follows: Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " Until A Beep Is Heard contact me http://koddoradia.pl/ |
New member Username: Barringtonw2Post Number: 3 Registered: Jun-13 | Hi Masterskay62 Yes it works great!!!! Many many thanks for your help its really appreciated Best regards barringtonw2 |
New member Username: Barringtonw2Post Number: 4 Registered: Jun-13 | https://www.ecoustics.com/electronics/forum/car-audio/716201.html#POST2014348 Hi Dekster Many thanks to you too for the info Kind regards barringtonw2 |
