New member Username: Emma3151991Post Number: 2 Registered: May-13 | Hi the Battery died and ever since I have needed a code for the CD player and its driving me mad the model no is RENEDW132-10. RNRD045014782. And the prod no is FD0705030157882 . I would really appreciate the help if someone knows the code. Thank you |
Gold Member Username: OpelopPost Number: 1284 Registered: Sep-12 | Emma New member Username: Emma3151991 Please, letters/numbers from the main bar code 8200xxxxtt123, 7200xxxxxtt123 or security code, as Q123 or T0U123 contakt me http://forum.kody-radio.pl |
New member Username: Emma3151991Post Number: 3 Registered: May-13 | The barcode is 8200300859tt995 |
Gold Member Username: OpelopPost Number: 1285 Registered: Sep-12 | Emma New member Username: Emma3151991 CODE 6085 contakt me http://forum.kody-radio.pl |
New member Username: Emma3151991Post Number: 5 Registered: May-13 | Its still beeping as thoughts wrong |
New member Username: Emma3151991Post Number: 6 Registered: May-13 | Is there any other possible code it can be or is there a certain button I have to press once I've entered the code Thank you |
Silver Member Username: DeksterPOLAND Post Number: 964 Registered: Sep-12 | Emma New member Username: Emma3151991 Code Entry as Follows: Switch Radio On - Display Shows " CODE " Then " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press and hold preset " 6 " To Enter Code Entry as Follows: Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " Until A Beep Is Heard contact me http://koddoradia.pl/ |
Gold Member Username: OpelopPost Number: 1287 Registered: Sep-12 | Emma New member Username: Emma3151991 remove radio from car first enter wrong code after that enter good code contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 965 Registered: Sep-12 | Emma New member Username: Emma3151991 Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body. To remove the radio can be found here: http://www.fitaudio.com/index.php?CategoryID=13 contact me http://koddoradia.pl/ |
Gold Member Username: OpelopPost Number: 1289 Registered: Sep-12 | Emma your code is 6085 contakt me http://forum.kody-radio.pl |
