Code Citroën saxo
Username: Nono5907
Bonjour je viens d'acheter une saxo pour ma conjoint et l'autoradio demande un code, le numéro de série est vf7s0hfxb57418483
Username: Opelop
Post Number: 1227
Nolan
Username: Nono5907
serial numbers from radio please
contakt me http://forum.kody-radio.pl
Username: Nono5907
Bonjour l'autoradio est encore mont� donc je ne l'ai pas, Upload
Username: Nono5907
Bonjour voici les infos de mon autoradio de ma saxo,
ModÚle autoradio PU-2294B (D)
Numéro de série autoradio CL040220749044
Numéro série voiture : vf7s0hfxb57418483
Merci
Username: Opelop
Post Number: 1230
Nolan
Username: Nono5907
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
